Tyre Not Monitored
Old Dec 1, 2017 | 06:08 PM
danveenstra's Avatar
Default Tyre Not Monitored
Hi, It's Friday here in the states and I'm on a road trip. I noticed a message on the center screen that says "Tyre not Monitored". There is an image of my car and the left front tire is red in color. Obviously the car is referring to the drivers front here in the states.
I looked at the tire and everything looks fine. Any thoughts? Is it that a monitoring device in the tire has gone bad?
I'm going to check for any responses tomorrow morning prior to leaving the hotel. Just thought of you folks immediately when I saw this error message.
Dan
PS: It's on my 2007 XK Convertible.
Old Dec 1, 2017 | 06:36 PM
pwpacp's Avatar
You are probably on the right track. Assuming the TPMS units have not been replaced, your car is at the limit of their battery life. You may know that the battery in them can't be replaced so you'll have to install new ones.
There are several threads here on the subject that should give plenty of info on them.
Old Dec 1, 2017 | 06:58 PM
Cee Jay's Avatar
Originally Posted by danveenstra
Hi, It's Friday here in the states and I'm on a road trip. I noticed a message on the center screen that says "Tyre not Monitored". There is an image of my car and the right front tire is red in color. Obviously the car is referring to the drivers front here in the states.............
To exactly WHICH "states" are you referring? MY driver's side is the left....
Old Dec 1, 2017 | 10:49 PM
ralphwg's Avatar
I get the tyre not monitored warning intermittently for the RF tyre. Sometimes it is on a daily basis for 15-20 minutes at a time. Now that I'm thinking about it don't think I have gotten the warning for the last ten days. Whenever I take it into the dealer (its still on warranty), I flag the issue and they replace the control module. Still get the warning though.
Old Dec 2, 2017 | 08:39 AM
CeeJay lol My mistake. The left front tire is correct. I have changed my posting to the left front tire.
Old Dec 2, 2017 | 08:46 AM
NBCat's Avatar
Exactly why I avoid driving through Arizona whenever possible.
The TPMS sensor(s) must be replaced as the service life of the lithium ion battery is about ten years.
Old Dec 2, 2017 | 09:04 AM
Sean W's Avatar
Dan look at post 10 in this thread. NTB should do this for free as it takes about 5 minutes.
https://www.jaguarforums.com/forum/x...arning-193137/
It will confirm a dead sensor.
Old Dec 2, 2017 | 11:11 AM
Cee Jay's Avatar
A dead sensor will definitely be a problem, but a low-or-intermittent sensor can cause problems also, therefore more frustration. I had a R-F problem, then Discount Tire put a new one on for me Gratis even though it still showed good. My problem went away.
Old Dec 2, 2017 | 07:31 PM
Thanks, Sean. I'm going there now to look at the thread. Dan
