V1 Blendmount & MirrorTap
Old Mar 9, 2014 | 12:53 PM
hdavidson's Avatar
Default V1 Blendmount & MirrorTap
I just installed my old faithful Valentine 1 radar using the Blendmount PN: BV1-2114 mount and MirrorTap power connection. I decided to go this route as I want to keep my XKR-S as stock as possible and this setup is easily removed without leaving a trace. I know there are better hardwired detectors out there but I also don't want an installer tearing my car apart to run wires and mount modules etc. The V1 has always served me well and saved my butt a bunch of times. The install was very straightforward - it only took about 10mins to complete after I knew what I wanted to do. The MirrorTap was also a snap to connect. The 2 wires matched my mirror hardness so took all the guess work out of it. Here's a few pics.
Attached Thumbnails V1 Blendmount & MirrorTap-img_20140308_153658.jpg   V1 Blendmount & MirrorTap-img_20140308_153722.jpg   V1 Blendmount & MirrorTap-img_20140308_174422.jpg   V1 Blendmount & MirrorTap-img_20140308_174522.jpg
Old Mar 9, 2014 | 04:36 PM
Ngarara's Avatar
Hmmmm - MirrorTap looks interesting. But why does it need an 8-foot cable (that's the HT-1096 which they recommend)? Presumably the cable goes into the mirror electronics, which are only a few inches from where I'd mount the V1.
I think I'd probably stick with the suction mount, which I position above the mirror to give the greatest range and make the V1 less obvious.
Old Mar 9, 2014 | 05:16 PM
hdavidson's Avatar
Ngarara- its 8 inches not 8 ft. And that is the total length. Most of the cable is hidden inside the mirror plastics so only about 3.5 inches are exposed.
Old Mar 10, 2014 | 11:43 AM
Ngarara's Avatar
The HardTap HT-1096, which is what their website recommends for the XK, is "8' Long" - and judging from the picture, that really is 8 ft. I'm guessing you used one of the other ones.
Old Mar 10, 2014 | 11:47 AM
MaximA's Avatar
I may just do this myself as the 2500 for a K40 that I don't need all the time seems a bit pricey. I also don't want the installer tearing up my car, as they always break something else in the process.
Old Mar 10, 2014 | 01:36 PM
MaximA's Avatar
So how exactly does it plug in? Does it just fit between the current plugs?
Old Mar 10, 2014 | 06:00 PM
hdavidson's Avatar
Correct. You are referring to the hardwire kit. I went with the MirrorTap power cord which is basically plug & play.
Old Mar 10, 2014 | 06:04 PM
hdavidson's Avatar
You just push the two pins into the corresponding connector. Here's a pic from MirrorTap's site. Our Jags have a slightly different setup. Refer to my earlier pics for what the connector looks like. You cant see any of the wires once you put everything back together so its a very clean install.
Old Mar 10, 2014 | 06:06 PM
hdavidson's Avatar
Also times the $ by however many other cars you drive... I can pull the V1 in 5 seconds and plug it into the JCW or Evoque and have the same protection.
Old Mar 10, 2014 | 06:08 PM
Ngarara's Avatar
Yeah, but which one? There are a load of different MirrorTaps, and I can't use their 'selector' because it just points to the hardwire kit.
Old Mar 10, 2014 | 06:13 PM
hdavidson's Avatar
I believe I used the MT-1009 but any of the MT-1000 Series will work. It may be better to go with a longer version to provide greater flexibility when routing the cable. Any excess can be hidden in the plastic casing behind the mirror mount.
Old Mar 11, 2014 | 08:20 AM
MaximA's Avatar
I think this is the way I'm going and ordering today. I can't justify 2500 if I can mount the detector right under the mirror, get better protection and upgrade whenever I want.
Old Mar 11, 2014 | 09:02 AM
Ngarara's Avatar
Jeez, for $2500 I'd expect carbon-fibre everything, with gold fittings! Maybe a laser cannon as well.
Old Mar 11, 2014 | 09:33 AM
MaximA's Avatar
Thank you for the review, I just ordered the exact same parts and an new V1. Should be here tomorrow!
Old Mar 11, 2014 | 09:34 AM
MaximA's Avatar
My point exactly and with the luck I've had with installers, they will break something else and when it doesn't work I have to go back to them.
Old Mar 13, 2014 | 10:05 AM
MaximA's Avatar
Don't buy this one its 8 feet long and not the mirror tap. I just made that mistake, just get the mirror tap that works with your detector.
Old Mar 13, 2014 | 10:11 AM
MaximA's Avatar
Can you please tell me which MirriorTap you ordered?
Old Mar 13, 2014 | 10:12 AM
Muddydog's Avatar
I just bought this one:
https://www.cobra.com/products/cobra-iradar/s120r
Totally stealth, feeds all info through your phone (which I already have installed in my former ashtray) and totally DIY install. For $300 I figured I could try it.
Old Mar 13, 2014 | 10:19 AM
MaximA's Avatar
I just bought the V1 and have it mounted but need the mirrortap and I accidently ordered the power tap.
Let me know how that works looks interesting and stealth which I like.
Old Mar 13, 2014 | 10:37 AM
hdavidson's Avatar
MaximA,
I recommend going with either MT-1012 or better yet the MT-1015. These will give you more options when routing/hiding the cord. Let me know if you need further assistance.
Good luck!
Hamish.
