Voltage gauge rate
Old Jun 9, 2023 | 09:04 AM
  #101
wymjym's Avatar
could this problem have to do with the security sounder?
#8 reply in this thread
https://www.jaguarforums.com/forum/x...010-xk-270667/
wj
Old Jun 9, 2023 | 10:26 AM
  #102
DGL's Avatar
DGL
wj
The dealer checked for quiescent battery drains with the car in sleep and found no problems. My problem is when I drive the car the battery is not being maintained. No codes or electrical problems. After a drive the optional ctek battery health indicator turns amber indicating a charge is required. If I continue to drive the car after about 2 - 3 weeks the car barely turns over when starting it. I have a new AGM battery and alternator.
Old Jun 9, 2023 | 11:49 AM
  #103
wymjym's Avatar
well then, back to this old thread
https://www.jaguarforums.com/forum/x...change-241034/
and alex's response #14
doesn't say much other than the agm had lower voltages...you have spent so much time, maybe the purchase of a 200$ battery is worth the risk, or not?
wj
Old Jun 9, 2023 | 12:41 PM
  #104
jahummer's Avatar
Originally Posted by DGL
How did you get your voltage readings, at the battery, torque pro, ADU etc. This is my second new AGM battery
​​​​​​I understand the ICU and BMS receive data from the battery and the ICU trumps the BMS if there is a problem.
Via OBD and VOM. Also I should note, BMS was replaced because the ECO batteries kept dying. That issue was never resolved. Fortunately the X150 doesn't have that problem. There's been discussions here whether AGM is appropriate for the X150 BMS. I know JLR did supply AGM batteries in some markets for some VINs and flooded as well. Others here have fitted AGM batteries with no issues on the facelift cars so I reckon that has nothing to do with it. You've a new alternator and new battery, so it must be an issue with BMS. Perhaps push the main dealer to seek assistance from JLR support?
Old Jun 10, 2023 | 06:55 PM
  #105
ralphwg's Avatar
I switched over to and AGM several months ago. I have experienced no issues. AT the ADU the voltage reads 12.3 with the car not started. While driving my range is 13.4 -14.2 volts. If I'm being repetitive forgive me, but could the BMS be at issue here?
Old Jun 10, 2023 | 09:23 PM
  #106
DGL's Avatar
DGL
Hey Ralph, Thanks for the info. I thought for sure the new alternator would fix this elusive problem. Now I have an extra good alternator as a paper weight. I had the car out today and the ADU never went above 11.8 and went as low as 11.2--no elictrical problems. Everything works perfectly. I should have did a battery voltage reading when I got home, but put the battery maintainer on immediately. I think the BMS is called the "battery negative cable" and is not too expensive. I'll go into the dealer next week to see about picking one up. I was very disappointed with the service I got at the dealer. The technician was very arrogant. Same dealer reinstalled my super charger under warranty after bending the actuator rod when it was in for warranty work for the torsion isolator and never told me. Good thing I had pictures of the SC, which I took, on their bench with the actuator perfectly straight. I'm OCD about this car and have maintained it in perfect condition.
Old Jun 13, 2023 | 08:28 PM
  #107
DGL's Avatar
DGL
Interstate recommends an AGM battery for 2012-13 models and a flooded battery for 2014-15. I think my 2nd new battery is already going bad. I'm giving it back to Interstate for inspection under warranty. Although, if they replace it they will replace with same AGM. I'm not sure why interstate does not recommend the premium AGM battery for 2014-15 years. Could it be that the size is a bit different (the AGM battery is a bit higher).
I've also ordered a new negative cable which includes the BMS. I'm hoping the the new BMS negative cable fixes the problem. I may have to switch back to a flooded battery. The negative cable, which includes the BMS, has the same part number for 2013 and 2014 year, but interstate recommends 2 different batteries.
Old Jun 22, 2023 | 08:12 PM
  #108
DGL's Avatar
DGL
Installed new negative battery cable which includes the BMS and had the new AGM battery checked by manufacturer, Interstate. Still no difference. The car is not maintaining the battery at full charge. Don't know where else to look, but for a loose ground wire.
Old Jun 23, 2023 | 06:26 AM
  #109
jagtoes's Avatar
Just an FYI but 12.3V is around 60% battery charge. . You need to see 12.6 -12.7 volts for 100% charge. Anything lower requires a battery charge (10Amps or better) and not a battery maintainer .
Old Jun 23, 2023 | 05:55 PM
  #110
DGL's Avatar
DGL
Over 13 for a full charge on an AGM battery for a full charge. I'm sure I'm going to kill another AGM battery.
My ADU read 12.2 volts when I connected the battery. On a volt meter before connecting it it was 13.04.
Old Jun 23, 2023 | 07:08 PM
  #111
McJag222's Avatar
I wonder if something is not right in the Aux Junction Box with that wire from it to the BMS. Might be time to have a look in there.
Old Jun 23, 2023 | 08:05 PM
  #112
DGL's Avatar
DGL
That would be the box behind the backseat? Do you know where to look?
Old Jun 28, 2023 | 01:41 PM
  #113
britannia's Avatar
Guy,
I got 13 yrs out of my two 6V golf (Trojan) batteries! Dealer said a record; so I asked for a discount! he said"NO" but gave me a free Hat!!
Cheers, Adrian, Founder member Seattle Jag Club, last one!!
George05
Jan 18, 2021 04:18 PM
jomo
Jun 8, 2020 06:31 PM
OzXFR
May 21, 2019 07:45 PM
jagtoes
Jan 17, 2019 07:01 AM
Earnest
Jul 29, 2014 09:20 AM
