waking her up
Old Apr 8, 2022 | 11:32 AM
jbmi's Avatar
Default waking her up
My 2010 XK has been asleep now for 6 months. Nicely covered in a garage and plugged into a C-Tek.
Sometime ago someone had posted a way to turn the engine over for a few seconds with out it starting, sort of to lube the internal parts.
Can't remember how to do this ?
Old Apr 8, 2022 | 12:30 PM
Stuart S's Avatar
Synthetic motor oil adheres well to internal moving parts, so I'm not sure if it does more harm than good by cranking but not starting the engine, especially if fuel is being pumped into the injectors without being burned. What harms an engine is water vapor from combustion that condenses in the exhaust system and crankcase and causes corrosion. Bringing the engine up to normal operating temperature will cause that old water to evaporate. But it also causes new water vapor so here we go again.
Old Apr 8, 2022 | 12:48 PM
80sRule's Avatar
This is probably the method you are talking about:
https://www.jaguarforums.com/forum/x...k-5-0l-240430/
I do that a little after the oil change and when starting for the year. Then I let it idle a half hour and take a flashlight around to make sure things aren't leaking. That's my post winter check, then I use it normal like from then on.
Old Apr 8, 2022 | 04:04 PM
steve_k_xk's Avatar
Pull the fuel pump fuse you'll get oil up into the heads and itll never start
Old Apr 11, 2022 | 10:55 PM
XKRAU's Avatar
6months is nothing to worry about. I had motorcycles that hasn't started for over 10 years. Drop fresh oil and fuel. Remove the spark plug leads or ignition coils and give it a 10-15 second crank without spark to circulate the oil. Bike runs great with the ignition back on.
When storing bikes/cars long term, I usually put a balloon over the exhaust pipes and inlet holes to minimise moisture entering the engine when the ambient temperature and humidity changes throughout the different seasons.
Old Apr 13, 2022 | 10:11 PM
lear60man's Avatar
I second what XRAU posted. 6 months is nothing.
jbmi
Jun 29, 2021 11:27 PM
Marco
Apr 6, 2014 06:40 AM
chazaroo
Oct 26, 2013 05:40 PM
jagtoes
Sep 4, 2013 11:49 PM
jimatvs
Mar 29, 2011 10:56 AM
