Water leaking into the passenger side of Jaguar XK 2007
Old Oct 1, 2018 | 02:34 PM
Microni's Avatar
Default Water leaking into the passenger side of Jaguar XK 2007
I have water leaking into the passenger side of my Jaguar XK 2007 - Think it is blocked A/C Drain Hose. What is the best way to repair - remove dashboard or transmition
Old Oct 1, 2018 | 02:44 PM
pwpacp's Avatar
Do some thread searches here and you'll find many discussions solutions to the "duck bill" blockage problem. I used an old gas grill rotisari spit shaft bending it with a bench vise and hammer such that I was able to attach a small box cutter blade on the end. I fished it into the drain hole, just above the transmission bell about 4 inches from the rear of the firewall. A few swiping motions and it cut right off and then came the water fall. Note thought that I also invested in a cheap bore scope (flex) camera so I could id everything first.
Again though, there are many threads on it and I think one even gave dimensions on how to make a cut off tool.
Old Oct 1, 2018 | 04:44 PM
Cee Jay's Avatar
https://www.jaguarforums.com/forum/x...lution-149349/
Don B
60
Dec 22, 2025 05:29 PM
LosRubios
Dec 27, 2024 09:37 PM
user 84302
May 11, 2018 03:27 PM
ALLEN68
Aug 28, 2017 08:10 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
