Water pump nightmares - shouldn't JLR step up?
Old Feb 7, 2020 | 12:20 PM
  #41
jahummer's Avatar
Originally Posted by bocatrip
Called my local Advanced auto parts. They don't lend out the pressure kits and what I've read from Jahummer above, the adapter was not available for our cars.I'm not sure what kit I should be purchasing. TXfireblade.....the kit you purchased on Amazon is no longer available.
A search online indicates several people have made their own using spare caps, about $9 from the dealer and a rubber tyre valve stem drilled through the center. Use a tyre inflator set to 15 PSI.
Old Feb 7, 2020 | 12:54 PM
  #42
TXFireblade's Avatar
if you look on Amazon you will see many very similar kits. In fact most look identical to the one I purchased. Pick one that’s Prime - easy return if it doesn’t work out, and I’ll send you my spare cap. Chances are it will be in there. Pick a kit that lists lots of European manufacturers. Or take road trip to Houston and we’ll track down the leak if there is one.
Old Feb 7, 2020 | 01:17 PM
  #43
bocatrip's Avatar
TXFireblade........I'm on my way!
slojotaa
Feb 4, 2025 08:35 AM
donathon
Nov 9, 2019 09:37 AM
pdfisherman
Aug 21, 2016 11:20 PM
roger.neill
Dec 22, 2013 08:39 AM
perezrp101
Apr 15, 2009 09:02 PM
