Waterpump small inlet pipe upgrade metal elbow
Old Oct 23, 2024 | 12:51 PM
trkyam's Avatar
Default Waterpump small inlet pipe upgrade metal elbow
For those of you that upgraded to the metal elbow which goes into the front of the water pump,
what did you use to ensure that it didn't leak other than the O-ring?
I have a persistant leak there after upgrading to the brass metal elbow, seems loose.
Old Oct 23, 2024 | 02:39 PM
DGL's Avatar
DGL
I believe I've read in a thread, with the metal coolant pipes you have to use the original seal ring not the one shipped with the pipe. I replaced all of my coolant lines and 2 piece plastic pipes with new one piece ones about 3 years ago. I wish the metal pipes were available at the time.
Do a search on the form. I hope you find the solution. Maybe someone who's already done it will chime in.
Old Oct 23, 2024 | 06:46 PM
guy's Avatar
guy
On the Land Rover forums (same engine) it was identified that the O-rings supplied are the wrong size.
Swap it out, and Bob's your uncle.
Old Oct 23, 2024 | 07:14 PM
trkyam's Avatar
Thanks for the tip, funny question but: is the o-ring suppose to go inside the hole?
The one supplied definitely won't fit.
Old Oct 24, 2024 | 08:02 AM
guy's Avatar
guy
give us a pic @trkyam . I don’t want to misinterpret you.
Old Oct 24, 2024 | 12:44 PM
trkyam's Avatar
I dound the answer, the supplied O-ring does NOT
Fit inside the waterpump inlet hole, will need to find
a smaller one.
O-ring goes in first, then the black or grey retainer clip
lastly the brass connector gera inserted.
Old Oct 24, 2024 | 03:13 PM
guy's Avatar
guy
go to a proper, commercial “fasteners” shop. They’ll have more O rings than you can shake a stick at.
Old Oct 24, 2024 | 04:03 PM
Cee Jay's Avatar
I think that's the same part I had to make myself using a mini-lathe and a 1/4 brass flange elbow. It took a couple hours to get it right.
Old Oct 24, 2024 | 04:09 PM
Cee Jay's Avatar
I found that picture!
This is the same one, right?
Old Oct 25, 2024 | 01:36 PM
trkyam's Avatar
impressive ceejay
trkyam's Avatar
unlike my phone typing abilities
RacingGreen87
Oct 5, 2022 03:12 PM
kenc
Sep 10, 2022 10:52 PM
Russ9898
Aug 23, 2022 04:18 PM
Hex Type
Apr 23, 2020 07:42 AM
rifziyad
Mar 8, 2018 06:08 AM
