wax on rag top
Old Feb 6, 2016 | 03:24 PM
2,4,6,trinitro's Avatar
Banned
Default wax on rag top
I accidentally got wax on the convert top with a buffer, underneath the rear window. Any suggestions how to remove it, other than using a quart of gas and a flare.
Old Feb 6, 2016 | 03:43 PM
Cee Jay's Avatar
I use a heavy dose of Dawn (blue) dishwashing liquid in a small bucket of warm water with a soft-to-medium bristle brush. Takes it right off.
Old Feb 8, 2016 | 06:43 PM
flyc2c's Avatar
A quart of gasoline is overkill. A pint is plenty. That being said I use Simple Green.
Old Feb 8, 2016 | 07:24 PM
Leeper's Avatar
Banned
just happened to me too I used isopropyl alcohol and a toothbrush worked great. I raised the top up a bit while getting it off the lower edge made things easier
Old Feb 9, 2016 | 11:31 AM
mosesbotbol's Avatar
If the wax has dried, a tooth brush will get a lot of it. I like the dishwashing soap suggestion. You'll want to apply Raggtop's or the like after you rid the top of wax.
Masking tape is necessity the next time you wax...
Old Feb 9, 2016 | 02:03 PM
Leeper's Avatar
Banned
He was using an electric buffet do I don't think making tape is an option. When I do mine every 18 mo's or so I either put the top down or put an old bed sheet between the to and the car then fold it up to cover the top where I'm working. I learned from the same mistake as you just did.
Someone mentored "Raggtop", I'm a proponent of 303 top pursuant myself live that stuff! Got mine on Amazon
Old Feb 9, 2016 | 08:49 PM
richzak's Avatar
I too am a big fan of 303 Aerospace Fabric Guard. It is a high-quality product and I apply the product with a high quality 1 2/1 to 2" paint brush.
Using the paint brush method, eliminates overspray unto the any of the paint surface.
Amazon.com: 303 (30606) Fabric Guard Trigger Sprayer, 32 fl. oz.: Automotive Amazon.com: 303 (30606) Fabric Guard Trigger Sprayer, 32 fl. oz.: Automotive
Old Feb 10, 2016 | 12:01 PM
Cee Jay's Avatar
303, three times a year at least. Always.
Kopi
Feb 19, 2016 08:41 AM
dsjohn
Feb 15, 2016 07:55 PM
robsti
Feb 3, 2016 08:12 AM
Computer Budda
Feb 1, 2016 10:26 PM
