Weird compression
Old Mar 5, 2020 | 11:23 AM
pauledddy's Avatar
Default Weird compression
Evening everyone,
Bit of a weird one, just had my engine rebuilt, and did a compression test and getting 90 across all cylinders (engine cold, throttle closed)
This seems a lot lower than expected, would this happen if the engine wasnt timed correctly?
thanks in advanced
Old Mar 5, 2020 | 11:30 AM
Mufc's Avatar
Compression tests should be done with engine up to temperature and throttle wide open.
Old Mar 5, 2020 | 11:58 AM
Cee Jay's Avatar
What Mufc said.
Throttle closed makes it so no air can enter the engine, therefore it's working against a lot of vacuum. Plus, warm is how engines operate, therefore test them warm.
Old Mar 5, 2020 | 12:25 PM
gkubrak's Avatar
Check out page 780 in the repair manual. It specifies how to do the compression test and how to interpret the results, and even what to do with low pressures.
Note there is no 'ideal' pressure reading. The important part is to make sure the lowest reading cylinder is within 75% of the highest reading one. Since you have the same readings on all 8, your compression is either good on all, or bad on all. Re-test per the manual and advice above.
Why is there no 'ideal' pressure? Because of the testing equipment. For an ideal gas, pressure and volume vary inversely. Assuming temperature and hose diameter are constant, using a hose 10 ft long will give you pressures 10 times lower, compared to using a hose 1 ft long. There is more space for the air to compress in the longer hose, therefore the pressure will be lower.
Old Mar 5, 2020 | 01:47 PM
pauledddy's Avatar
Yeah I thought I did it wrong
When I get the car back I'll do it properly. But as they're all near enough exactly the same is that a good thing?
only reason I ask is that its seems like it's misfiring, and I can't find the fault, had injectors tested, they're fine (however some seals were a bit damaged so could be that), so trying to figure out this issue is annoying me!
Old Mar 5, 2020 | 01:50 PM
NBCat's Avatar
Are there any DTCs stored in the system due to the misfire(s) situation?
Old Mar 5, 2020 | 02:27 PM
pauledddy's Avatar
Only thing i saw was under the pending codes (no EML) was a knock, but i didn't get a chance to look at it with the SDD.
Old Mar 5, 2020 | 04:46 PM
gkubrak's Avatar
Keeping the throttle open won't make a difference. All 8 spark plugs are removed for the test, therefore there is only vacuum being created in the cylinder being tested.
But definitely get it up to temp before testing again.
Lecus
Feb 3, 2020 08:20 AM
superdave
Aug 9, 2017 05:30 PM
Mendo XK
Nov 6, 2012 11:03 PM
SeamlessAutomotive
Jul 14, 2012 05:50 AM
hoodun
Jul 6, 2011 02:25 PM
