What did you do to your X150 today?
Old May 2, 2023 | 09:33 PM
  #2021
McJag222's Avatar
Originally Posted by mhminnich
Several days and a large blood offering later, I got the coolant crossover pipe off the xkr to replace a hose. I had to drill the head off of a posidrive bolt that was gutted (not by me). I tried a screw extractor but couldn't get good purchase, and of course it was the hardest to get to!
Is that the pipe connector that goes to the thermostat housing?
Old May 2, 2023 | 09:48 PM
  #2022
mhminnich's Avatar
Yes. That's the one.
Old May 4, 2023 | 12:47 PM
  #2023
KJsJag's Avatar
Did the floppy glove box door repair. Used the zip tie method and it seems to work great. took about 30 minutes.
Old May 4, 2023 | 02:22 PM
  #2024
George Abitbol's Avatar
What is that?
Old May 4, 2023 | 04:35 PM
  #2025
V7Sport's Avatar
Originally Posted by George Abitbol
What is that?
The pin that holds the upper end loop of the string attached to the glove box damper mechanism fails. Some people have Ty-wrapped the loop to the hole where the failed pin went through rather than fix the pin. Search the forum for specifics.
Old May 4, 2023 | 05:32 PM
  #2026
KJsJag's Avatar
What is that?
As V7Sport said. Options are to drill a hole in the drop arm near where the cable originally attached and insert a cotter pin or bolt, or as I did, just use a good zip tie and run the cable loop through it and it should be good to go. Glove box now opens slowly as it should instead of slamming open in an entirely UN-Jaguar fashion. :-)
here's the thread. down about post #38
https://www.jaguarforums.com/forum/s...errerid=227996
Old May 5, 2023 | 06:10 PM
  #2027
mhminnich's Avatar
Determined my coolant leak is under the SC, so back in for that unpleasant task again. I did the valley hoses 3 years ago. Seems too soon for those to have failed already.
Old May 5, 2023 | 06:18 PM
  #2028
McJag222's Avatar
Just had mine done - hope they last longer than 3 years.
Old May 6, 2023 | 08:31 PM
  #2029
VirginiaDave's Avatar
Mopar, does the metal pan also include a replaceable ATF filter?
Old May 6, 2023 | 08:47 PM
  #2030
MoparDude's Avatar
Yes according to manufacturer, filter was included.
Old May 12, 2023 | 01:57 PM
  #2031
Brachacz's Avatar
Not exactly today but took it to the track, wonderful experience!
Couldn't turn off traction control completely though which threw me off.
Tried pushing the Trac DSC button for a couple seconds (with Trac DSC on) and all it did was just turn on the regular traction control again.
Old May 12, 2023 | 02:23 PM
  #2032
MoparDude's Avatar
Usually have to hold it around 12-13 sec for mine to turn off.
Old May 12, 2023 | 02:47 PM
  #2033
Brachacz's Avatar
Do you then release it at this 12-13s mark for it to work or does it say it's off on in the gauge cluster and then you release?
Old May 12, 2023 | 02:50 PM
  #2034
MoparDude's Avatar
Basically just hold it until it flashes a warning message 'DSC turned off' in instrument cluster.
Old May 12, 2023 | 03:01 PM
  #2035
Brachacz's Avatar
Thanks!
Old May 12, 2023 | 09:39 PM
  #2036
mhminnich's Avatar
Got the SC out this afternoon so i can look for the coolant leak in the valley. What a hassle!
The valley hoses "look" like new after 3 years stewing down there. Well see if that is the case.
Old May 13, 2023 | 09:39 AM
  #2037
McJag222's Avatar
Can you post a few pics looking down into the the valley - thanks.
Old May 16, 2023 | 11:31 AM
  #2038
shemp's Avatar
Did oil change and reset the service required message...... ON THE FIRST TRY!!!!!
I swear I'm not lying.
Old May 22, 2023 | 07:25 AM
  #2039
steve_k_xk's Avatar
Hello old friend ...not this again 😂 Ive seriously lost count ..
**Word of warning even with the amount of experience Ive had I would not recommend compressing the front springs like this !!! use a proper wall mounted spring compressor or remove shock and have suspension shop compress spring for you and remount.
Always check the replacement shock is fully functional at the start of the job and doesn't throw any codes
So satisfying and such a relief getting that top nut on !!!
Make sure you release the braided brake hose from the body to prevent it stretching & damage (10mm bolt)
A lick of paint looks brand new
Old May 22, 2023 | 02:27 PM
  #2040
kj07xk's Avatar
You are the expert on this now! I did that compression once, a bit nerve wracking. Last time the replacement used shocks came with springs attached, so woohoo! Didn’t think about releasing the brake line, tied the knuckle up to keep it from falling that far, but your way certainly gives more space to work. Nice job!
