What did you do to your X150 today?
Old Dec 2, 2020 | 07:46 PM
  #1501
steve_k_xk's Avatar
I was inspired by the later model Face lifted xkr they have the black fascia / Nat unit however unavailable for purchase unless you buy the info unit in its entirety.
sure thing I’ll get pic up for you once fitted 👍👍👍
Old Dec 2, 2020 | 08:51 PM
  #1502
Stuart S's Avatar
Steve,
Nicely done! That looks great, just like the OEM "Piano Black" trim finish. It's a more modern look. I hope you do the same thing to all the other silver painted bits and pieces so all the trim matches. You might even want to wrap the (wood veneer/spun aluminium?) dash trim in gloss black to complete the Piano Black look. Just food for thought ...
Stuart
Old Dec 2, 2020 | 09:13 PM
  #1503
steve_k_xk's Avatar
Thanks Stuart
Good thinking , the info unit facia was the last piece of the puzzle as all my trim including the air con vents have been painted from that factory cheap looking grey to black in order to complete the look and yes it really has modernised the interior l
Old Dec 2, 2020 | 09:58 PM
  #1504
Stuart S's Avatar
Thanks Stuart
Old Dec 2, 2020 | 10:58 PM
  #1505
steve_k_xk's Avatar
Sorry about the quality it’s S@#thouse , although you do get a idea of how it ties in
ill get proper photos tomorrow once It’s installed correctly
Old Dec 5, 2020 | 04:18 AM
  #1506
MarkyUK's Avatar
Got mine back from my indy after small service, sc nose replacement, sc oil change, spark plug change and 6% ss bolt-on pulley. They also showed me that my old pulley was not stock and a smaller 7.5% performance ali one
As expected (and reported by many) 3 of the plugs were a complete pita to remove. they had to soak them overnight with plusgas. When they were all off they found them to be in pretty good shape (see pic below). They said I could get them ultrasonically cleaned and put aside for the 210k miles
They also discovered coolant around the pump so replaced that as well along with the long SC coolant pipe which was brittle (all old parts were returned to me). There was quite a congealed mess in the coolant, but I suspect it was the original stuff from factory (Ive not topped up in my ownership). So system was flushed through 3 x
One thing they did say was that they had to put in twice as much oil in the SC that they took out. Oil condition was fine (still light amber) and they couldnt see signs of a leak....so I wonder where it went?? The original coupler was in a complete state but once changed there was still a slight ratrle from the SC, they suspect some bearing damage due to lubricant being too low....which may improve with the new correct oil level.
Based on the slightly larger pulley they said that I'll be down on power...until I have the tune done that is. But that's for next year
One thing I have noticed is that coolant takes a lot less time to come up to speed...perhaps due to the congealed mess stopping circulation?
Old Dec 5, 2020 | 03:55 PM
  #1507
Sean W's Avatar
Only have a pic of a trial fit at this stage however it looks great
It does look great. Is it paint for plastic specifically? Looks like it has some metal flake in it? I sense a winter project coming on for me.
Old Dec 5, 2020 | 04:43 PM
  #1508
George Abitbol's Avatar
Originally Posted by ralphwg
Ordered a new footrest from Spain for about $60. delivered. Will show pictures when delivered and installed.
Hey, I'd be interested in that, too...kinda disappointed it's not there by default...
From which store did you get it? How is it mounted?
Thanks for the info!!
Old Dec 5, 2020 | 07:21 PM
  #1509
steve_k_xk's Avatar
Thanks Sean that terrible eyesore of a info unit is finally gone now and it looks completely factory
Yes your correct there is some very subdue flakes in there , I was thinking if I don’t like I can have it resprayed again nevertheless I quite happy with the result .
In terms of the paint it’s just a base coat then cleared , however make sure a plastic primer is used first which should be readily available at every panel shop as it’s applied to new bumpers , side mirrors , outer door trims etc
Old Dec 12, 2020 | 07:35 PM
  #1510
Cee Jay's Avatar
GAAAAAHHH!!!!!!!!!
Now my poor XKR has touched SNOW! Ugh! I will now have to sell it.
(had to back it out so's to be careful while running gas pipes for a garage furnace)
Old Dec 12, 2020 | 07:40 PM
  #1511
ralphwg's Avatar
I'll give you 10k for it since it has been "snowed"
Old Dec 12, 2020 | 08:07 PM
  #1512
Cee Jay's Avatar
Old Dec 12, 2020 | 08:16 PM
  #1513
Stuart S's Avatar
Originally Posted by Cee Jay
GAAAAAHHH!!!!!!!!!
It looks like it didn't get snowed on, and was just driven on snow. It's an easy fix, just get a new set of Miche ... uh, tires.
( an inside joke)
Old Dec 12, 2020 | 08:46 PM
  #1514
tberg's Avatar
That's worse than a salvaged title in my book. I'd only offer $7500.00.
Old Dec 13, 2020 | 12:04 AM
  #1515
AlexJag's Avatar
Sponsor
Wait so why downgrade your pulley?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Dec 13, 2020 | 04:32 AM
  #1516
MarkyUK's Avatar
Cos I wanted a nice shiny SS one silly...doh!!
In truth even though I am happy with the power, I'll probs go for a tune in the Spring.
SC had to come off for new oil/belt/nose so they only charged me an hours labour for fitting the new pulley, if I'd chosen to have it done at a later date would have been 2-3hrs
Old Dec 13, 2020 | 09:30 AM
  #1517
Sean W's Avatar
Cee Jay, I'm so sorry to hear of this tragic event. It can no longer be advertised as "Never Seen Snow". I would match Ralph's offer but have to agree with Ted - totaled now imo.
What I can do though is offer you $7500 plus 2 nights and the Rmada Inn, Duluth, MN, with complimentary breakfast. Airfare not included. Blackout Dates apply - January 15 2021 - January 12 2022 - all other dates available. (FYI, that's not a TYPO, they can't afford a real Ramada Inn up there). It's been awhile for you since you last were there so I want to assure that absolutely nothing has changed in the decades since your departure:
https://www.visitduluth.com
Again, very sorry for your tragedy.
Old Dec 13, 2020 | 11:11 AM
  #1518
Cee Jay's Avatar
I remember when that Ramada was built, the rotating restaurant at the top was a major selling point. Also, my third wife is buried in Duluth.
What a hell hole, especially between September and May.
I feel sort of like the victim of a stalking now though......
Do I know you from way back?
I got the heebeejeebees now.
Old Dec 13, 2020 | 11:28 AM
  #1519
Sean W's Avatar
No, just in some previous thread where I mentioned I lived in Minnesota and you recalled that you lived in Duluth.
Old Dec 13, 2020 | 01:58 PM
  #1520
Cee Jay's Avatar
Still, guess I'm either weird or old, because I don't remember many details about members in here.
