What did you do to your X150 today?
Old Feb 8, 2023 | 09:23 AM
  #1961
Cee Jay's Avatar
No point on the forced induction they run out of steam at 6500rpm different with the n/a - more rpm = more bhp .
These engines share the same valve springs , valves as the AM 4.3 vantage (4.7 larger valves) and have also been tested up to 7500.
If the blower engine's power band is huge but drop off at 6500 rpm, that means its time to SHIFT, get back INTO that huge power band. RPM does not equal power or speed. Usage OF the power band is what allows power to be used.
The BHP you tout at 7500 rpm is still much lower than the supercharged power at 5500 rpm.
Therefore, blower at 5500 beats the snot out of over-revving the n/a engine.
Old Feb 8, 2023 | 04:11 PM
  #1962
pbandj's Avatar
Got new tires, Firestone Firehawk Indy 500. Hooking like crazy and the grip is phenomenal.
Old Feb 8, 2023 | 04:22 PM
  #1963
steve_k_xk's Avatar
No question about that at all and plus the torque out of the forced induction unit .
For me Cee Jay the goal is to get my n/a just as quick or as close to a stock xkr 4.2 once that is achieved I'll either jump ship into a 5.0 xkr or 5.0 ftype where there's no need to play around with diff ratios or up the rpm limiter
Old Feb 8, 2023 | 05:23 PM
  #1964
Cee Jay's Avatar
From my Drag Race Engine and Racing days.......
"Max Torque Curve at the Shift Recovery Point".
Horsepower isn't the magical wizard, it's how you use it.
Old Feb 8, 2023 | 05:50 PM
  #1965
pbandj's Avatar
Originally Posted by BlkC4t_XK14
I attempted to post a sound video clip but no sound only visuals.
Any droning?
Old Feb 8, 2023 | 06:08 PM
  #1966
Marco75's Avatar
Took the XKR on a the 63rd annual NY Metro PCA Snowflake rally this past Sunday. Finish 4th overall out of about 30 cars and 1st Jaguar out of the 3 entered.
Old Feb 9, 2023 | 10:05 PM
  #1967
steve_k_xk's Avatar
Cee Jay I really don't get what your trying to say ?
The n/a went 13.6 @6250rpm then 13.4 @7400rpm with increased limiter
Old Feb 10, 2023 | 10:40 AM
  #1968
Cee Jay's Avatar
Never mind, it'd take too long to explain.
Old Feb 11, 2023 | 08:12 AM
  #1969
arenaej's Avatar
On hard acceleration, the other day, my check engine light came on. The car was running fine, so I cleared the code -p0171- but it quickly returned. Took it in to my Indy shop, they did a smoke test and found some old, brittle vacuum lines were cracked and leaking. He also found that the air intake wasn’t properly installed and also showed some smoke. Happy to report that it’s running great!
Old Feb 13, 2023 | 07:28 AM
  #1970
Dops's Avatar
Default Charged the battery 😀
Had a flat battery on my XK 2014 Coup today. Sounds like a common thing.
do I just live with it?
Old Feb 13, 2023 | 07:57 AM
  #1971
panthera999's Avatar
1. Battery age: this car needs >12.5 v consistently, more like 12.8. Use an AGM, quality unit, and try to keep it to 12.8 or above. Use a battery maintainer every night.
2. Don't leave your key near the car. Car detects it and may not shut down properly.
3. Car shuts down to about 50 milliamps in 3 minutes if you double lock it. Double lock it every time you shut it off, and it will shut down quicker.
Good luck.
Old Feb 13, 2023 | 10:20 AM
  #1972
New owners:
Said this a few times: the seals harden and shrink on these over the years. This p0171 code indicates that the Long term Fuel Trim (LTFT) mixture has leaned out beyond 20%, when it should be zero. The only practical way to find all the leaks is a smoke test. The brittle lines mentioned above were likely the thin grey ones going to the AIR unit from the back of the throttle body. Incredibly fragile, they break easily. A poorly fitted intake to the throttle body is really easy to do, as the part on the underside of the TB gets missed. In addition, o-rings shrink, on various lines, as well as the 4.2 model injectors. The oil cap and the dipstick seal also dry and leak. Lots of small leaks add up.
If you want to know if you have vacuum leaks, check your LTFT on each bank. If either varies more than 5% or so, you likely have a leak somewhere. Leaks can affect an individual bank, but usually affect both. The only practical way to find the problem is a higher pressure smoke test -- meaning use something stiffer than a rubber glove over the throttle body.
Good luck.
Old Feb 14, 2023 | 12:14 PM
  #1973
04xtypeguy's Avatar
I gave my XKR interior leather a good cleaning and TLC this weekend. It's looking tip top.
Old Feb 16, 2023 | 03:36 PM
  #1974
Hockey_Steve's Avatar
Going to the shop tomorrow for new rad hoses, thermostat and housing and a new door latch so the car actually locks.
Old Feb 22, 2023 | 04:06 PM
  #1975
BagelConsultant's Avatar
Got mine back from polishing and ceramic coating today, very happy with how it turned out. Sadly the sun wasn't out for the after photos but you can see how the Botanical Green pops under the lights in my detailer's garage:
Old Feb 22, 2023 | 05:46 PM
  #1976
BlkC4t_XK14's Avatar
No, no droning. I still have the singular center section. Nice growl.
20201106_Jaguar-Exhaust-18-2.mov
Old Mar 1, 2023 | 03:57 PM
  #1977
Wm. Lyon's Avatar
Originally Posted by Sean W
@Wm. Lyon Would you ming asking them? They look pretty darn good and it would be cool if we could get our hands on a set.
Well, let me tell you, you don't want these tips! Already starting to pit/rust! Total waste of money! Now looking into the Mina exhaust.
Old Mar 1, 2023 | 06:37 PM
  #1978
steve_k_xk's Avatar
Black car paint them black they'll look fine
Old Mar 2, 2023 | 02:59 AM
  #1979
George Abitbol's Avatar
Car. Too. Black.
Old Mar 2, 2023 | 05:26 AM
  #1980
Wm. Lyon's Avatar
Those look great in black!👍 But, kinda trying to convince myself into a Mina back box!😂🤣
By the way, do you still have your original back box in place? Also, did you notice much difference (in anything) after installing your X-pipe?
