What gas should I use?
Old Sep 8, 2025 | 02:37 PM
ericmcn's Avatar
Originally Posted by sony2000
I think Subaru Motors should have their cars run on higher octane, because they have a very high rate of blown head gaskets! I suspect their knock sensors are not adequate.
The Boxer Had a weakenss in the design, Subaru had many law suits and stuff - also because many were modofied that made it even worse - they are not as bad as you think - much of it went down to poor ownership and neglect - I had the 3.0 EZ30 in my old SpecB and it was a peach of an engine and sounded the business - sold it for £6000 last year around 140k miles - more than I paid for it, so I was effectively getting paid to drive it
I tend to keep away from turbo cars personally and never owned one
Old Sep 8, 2025 | 03:19 PM
Cee Jay's Avatar
ACTUALLY, lower octane fuel burns faster and has more concussive force than higher octane. In engines, it's the compression that would cause detonation prior to ignition that would kill an engine quick. Higher octane is less volatile under compression, which is why higher compressions can be used, which ALONE provides more power. Higher octane is merely a requirement OF that higher compression, and high octane actually decreases the ultimate power output slightly.
Old Sep 8, 2025 | 03:24 PM
HealeyJag's Avatar
Default Octane??
Will continue to run high octane in my car..
Just filled up..$3.25 for 93 octane.
Old Sep 8, 2025 | 03:35 PM
Cee Jay's Avatar
You have to do that, because higher compression. The ECU would retard the ignition to prevent detonation if the knock sensors detected anything bad.
Old Sep 8, 2025 | 04:45 PM
davidmaria1's Avatar
Shiite! I paid $4.19 for Shell 93 this a.m.
I remember seeing some relative bargains in the Indialantic real estate market recently.......
Old Sep 8, 2025 | 04:54 PM
HealeyJag's Avatar
Default gas
Alot depends on STATE taxes per gallon...
Condo and home Market exploded after we bought..2018
has gone down 15%..but this is after it went up 100% after 2020
We love it here
jaguny
Aug 9, 2012 02:17 PM
MiaXfsc
Sep 22, 2011 10:36 PM
Steve W
XJ40 ( XJ81 )
Mar 4, 2011 11:24 PM
MDJag
Nov 17, 2010 09:30 PM
