Wheel offsets
Old May 26, 2025 | 08:04 AM
luv2fly's Avatar
Originally Posted by sony2000
Would this work? Add spacers to your mag until you get the correct look and movement. If the rear offset is 26mm and a 15mm spacer then that should mean that your next mag would have an offset of 26+15= 41mm. SNAPCHAT's vibration was probably caused by a lack of center rings. For which there are only a few, if not two sizes, for automobiles.
That's actually backwards. 26mm offset + 15mm spacer is 11mm offset. There's a video on utube showing an owner putting 15mm spacers on the rear with Sentas and 20 on the front with Sentas. The problem with too little offset, i.e. wheel farther out is that you can catch the fender lip, bend the fender, puncture the tire.
@Gomes is spot on. Wish you weren't in Idaho @SNAPCHAT . I'd love to have the Sentas. Already running the spacers on my Jupiters. H&R Trak+ 20mm DRM Wheel Adaptor Bolt 5/108 Center Bore 63.3 Stud Thread 12x1.5 ebay, MISHIMOTO 15mm SPACERS MMWS-006-150BK 5X108, 63.3/4, 12X1.2 AMAZON HGA Performance
Old May 26, 2025 | 09:14 AM
Tornado's Avatar
I can't help directly because I have a 5.0 car with the different rear offset, but I will say that there are massive amounts of space in the wheel wells in the front and truly massive amounts of space in the back of these cars. Not 11-inch-wheels-in-front C4 Corvette levels but not far removed. About a month ago I did pretty much the 5.0 XKR-S size/offset for my special ordered wheels in the back and 9.5 ET45s in the front; and while I wasn't brave enough to put my money on the line to try I suspect I could have done the 10.5 ET50 fitment on the front as well now that I actually have them in hand.
Old May 26, 2025 | 11:29 PM
kj07xk's Avatar
With pontoons like that, no need to worry about floods.
Old May 27, 2025 | 03:26 AM
Tornado's Avatar
I really liked how my square setup on my Corvette (originally 315/35-17s, later 295/80-18s) drove and the ability to do 4-corner rotations. I did strongly consider doing something similar for this car (with 295/30-20s) to try and make the steering a bit heavier, but since I was going to be changing the steering rack to the F-Type unit and installing Spires springs, plus the lead times/risk with ordering custom offset/bolt pattern wheels if they didn't fit, I decided to go with something more much more aggressive than stock but not that aggressive so I knew it would fit.
Old May 27, 2025 | 09:05 AM
Cee Jay's Avatar
The stock rear wheels on the 5.0 cars fit wonderfully on the front. Not the 4.2 cars though.
Old May 27, 2025 | 12:13 PM
Tornado's Avatar
I actually used your posts on the subject as my guide for when I was choosing how I wanted the offset on the wheels I got for the front machined.
MartynL
May 8, 2018 02:37 PM
Hank Scorpio
Apr 25, 2018 02:26 PM
milleniumaire
Mar 8, 2017 03:44 PM
Pumpkinate
Jun 23, 2015 05:39 PM
Manofsteel
Sep 21, 2012 10:35 AM
