Where's the DIY section?
I'm used to seeing a sticky atop other forums with DIY under each model (ie - X150). I see the "How to" section which is pretty small. Where's the DIY's on doing the oil pan, water pump, detailed oil changes, etc? I've obviously looked in the X150 forum but also the general forum did not see it
Thanks Norri I saw that but it is severely lacking to say the least. Could we perhaps have a Admin put a DIY section and, if so, I'll be happy to detail each of my DIY's with pictures and I'm sure others will do the same. Some of the helpful ones might include:
Oil changes, Oil pan replacement, engine and cabin air filter replacement, spark plugs, serpentine belts, any/all schedule maintenance, brakes, diff and tranny oil replacement, light bulbs, water pump replacement, etc
It would make it much easier than trying to do searches
Marque
Dec 16, 2015 05:34 AM
