Whistle
Old Mar 6, 2024 | 02:53 AM
PeterRicketts's Avatar
Default Whistle
Hi All
My XKR is making a whistling noise at 2-2500 rpm
My mechanics have spent 4 hours trying to find out what it is. Any ideas?
Old Mar 6, 2024 | 08:26 AM
slick.one's Avatar
Is the A/C running?
Old Mar 6, 2024 | 08:30 AM
Welcome to the forums Peter,
A little more information would be useful. Model Year would confirm it's an X150 and give a clue whether this is a 4.2 or 5.0 ......
Old Mar 6, 2024 | 11:24 AM
Prettykitty's Avatar
If the mechanic isn't finding anything wrong with the car while stationairy (and I'm assuming through a range of revs), you might look for something aerodynamics related. If not mechanical, it typically takes wind/air movement to whistle. Such ideas might be loose shielding or air deflectors, trim coming off or loose, a change to window/door gaskets... Hope you find something - I really dislike spurious noises and rattles.
Old Mar 6, 2024 | 01:04 PM
Default Jaguar Whisto
Car is X150 5 litre
Old Mar 6, 2024 | 05:29 PM
Cee Jay's Avatar
You can use this link to go to your User Control Panel and create a signature with your details, that's the easiest way to give this info. Edit Your Details at the top and you can put in as close a location as you feel comfortable.
User Control Panel
Old Mar 6, 2024 | 06:04 PM
B SMITH's Avatar
Originally Posted by PeterRicketts
Hi All
I don’t know how to link this so here’s a picture of a thread I replied to…
Old Mar 7, 2024 | 02:07 AM
RichardS's Avatar
Hi All
The noise is presumably occurring whilst the car is standing still? If your mechanics still can't pin point the area of the noise after 4 hours, then I suggest that the main problem lies with the mechanics rather than the car. 🙁
Richard
Old Mar 7, 2024 | 08:14 AM
sony2000's Avatar
Turbos have an inherent whistle. Some more than others. That could be you!
Does your turbo have its own dedicated oil supply? Check or change it.
Old Mar 7, 2024 | 08:24 AM
kj07xk's Avatar
Turbo?
Old Mar 7, 2024 | 08:40 AM
Cee Jay's Avatar
Originally Posted by kj07xk
Turbo?
TURBO?????
Old Mar 7, 2024 | 08:42 AM
RichardS's Avatar
I guess that you mean supercharger? These also have a whistle although surely any competent mechanic would recognise that immediately?
Richard
Old Mar 7, 2024 | 10:06 AM
Stuart S's Avatar
User Control Panel
The Forum rules exist for a reason - to help us help you. It's a two-way street.
@GGG and @Cee Jay went out of their way to help the newbie OP. And to what end?
I noted that the OP's Public Profile remains unchanged, and he hasn't created a signature. Until he does so, I will not post my comments regarding his inquiry. You may want to do the same.
Old Mar 7, 2024 | 10:56 AM
sony2000's Avatar
I stand corrected. Your gear driven turbo, (can be belt driven), called a supercharger, could be the source of the noise. If you had an exhaust driven turbo, I would say the same thing. Turbo is really a misnomer. We can call it a, turbine compressor, to be more exacting I believe.
So your turbine compressor could be whistling. I wouldn't loose much sleep over it. If the speed of the tips of the turbine blades reach the speed of sound, you will hear it. Just to muddy the waters even more!
Old Mar 7, 2024 | 11:06 AM
Cee Jay's Avatar
But, superchargers don't HAVE a turbine. They are positive displacement inter-meshed gears/lobes. A totally different beast using different physics.
You were wrong, no big deal. Even I have made (three) mistakes.
Old Mar 7, 2024 | 03:41 PM
wymjym's Avatar
"In definition a turbocharger is powered by a turbine that is driven by the engine's exhaust gas
And in definition a supercharger is mechanically connected to the engine's crankshaft by means of a belt or gear.
Now what your talking about is a centrifugal supercharger. Some people see it simply as a belt driven turbo because basically it is. Like a Turbo it's also powered by a turbine but instead of being powered by the engines exhaust it's connected to the engine's crankshaft by means of a belt or gear."
My old shop used to install Paxton Super Chargers in MBs...back in the day they were trash, the ball bearings would give out, they didn't flow enough air, and Vince would swear that when I installed it I warped the housing. (no warranty just send more money)
Good memories!
wj
tcsamir21
Jan 23, 2023 02:48 PM
AlexJag
May 26, 2021 08:49 PM
smose2400
Mar 17, 2018 11:14 PM
powerhouse
Sep 19, 2014 03:40 PM
