Whistling noise at dashboard area
Old Sep 30, 2018 | 10:41 AM
DannyJ's Avatar
Default Whistling noise at dashboard area
Hi all
I hear a whistling noise that seems to come from my XK 2008 dashboard area.
It changes and follows engine revs. It's present without A/C and radio/CD. Never stops while engine is on.
Attached a short audio file over several locations around the dash
Any idea what may be the source ?
File Type: mp3
Old Sep 30, 2018 | 12:44 PM
Patrick Wong's Avatar
The engine air intake has a hose that pipes intake noise to the passenger compartment. Perhaps this is the source of the noise that you have noticed?
Old Sep 30, 2018 | 03:28 PM
DannyJ's Avatar
I don't know...
where is it ?
Can you hear it in your XK as a whistle ?
Old Sep 30, 2018 | 03:41 PM
1. Find the engine air intake black plastic tube which runs along the front of the engine. Note that it has a rubber hose which connects to the engine compartment firewall. That hose transmits sound.
2. See if you can hear this whistling sound while you are standing outside the car, the hood is open and the engine is running. If you can hear it, try to localize the source of the sound. Maybe you have a slight leak in the air intake which allows the whistling to develop.
3. Disconnect the rubber hose mentioned in #1 above and see if that affects the whistle as heard in the passenger compartment.
I do not hear a whistle sound in my 2007 XK.
Old Sep 30, 2018 | 03:51 PM
DannyJ's Avatar
Thank you Patrick for the detailed explanation
Do you mean the hose coming out of the red arrow in the attached picture?
Old Sep 30, 2018 | 04:19 PM
TexasTraveler's Avatar
If your referring to a high pitch whistle at or around 1200 rmp’s, it is probably the AC line noise that has been referenced in other threads. There is a Jaguar TSB for it, where a washer/spacer needs to be installed to stop noise...
Old Sep 30, 2018 | 04:34 PM
DannyJ's Avatar
It's not at 1200 rpm. It is continously at all rpm's even with A/C off
Old Sep 30, 2018 | 04:43 PM
I just saw you posted a sound clip, not the A.C. noise I was referring to...
Old Sep 30, 2018 | 10:33 PM
Yes
Old Oct 1, 2018 | 02:56 PM
DannyJ's Avatar
Well Patrick, yes the whistle is very similar to what I hear just near the air intake hoses.
I don't know if there is a leak and how to find it...???
If can't find the source of the noise/leak, is it ok if I disconnect the hose going in the cabin?
Danny
Old Oct 1, 2018 | 04:08 PM
pwpacp's Avatar
The hose that leads from the intake air box/tube to the firewall is only there to provide intake sound, so the you get a "sportier" sound in the cabin. I found it anoying (eventhough mine is a vert) and pulled the hose off, pushed a wine cork in it (being careful to not shove it in too far to easily pull back off) then reassembled the hose to the intake air box. The result was a much quieter cabin with the top up and might stop the sound you are experiencing. If I'm off base on what you are seeing please excuse my post.
If you disconnect it at the air box you have to cap off port so as not to allow unfiltered air into the intake stream.
Old Oct 1, 2018 | 04:13 PM
Danny
I suggest you remove the large black plastic air duct and inspect for a crack. If necessary you could disconnect the hose leading to the cabin but as previously suggested, you need to plug any openings.
Old Oct 2, 2018 | 09:34 AM
DannyJ's Avatar
Did you push the cork into the hose or into the air box ?
Old Oct 2, 2018 | 09:44 AM
pwpacp's Avatar
I made sure the cork was clean, ie. not flaking little pieces off, slid it into the airbox port then reattached the hose. I have a hose clamp tool that allows the clamps to not get damaged so that made the job a breeze but, as you probably know, pliers will do the trick too. I also made sure the cork only entered the port part way so that it was easy to remove if I wanted and also did not enter the air stream within the air box. The cork was a tight fit so I was confident it wouldn't work it's way forward into the box.
Hope that helps.
Old Oct 2, 2018 | 09:58 AM
DannyJ's Avatar
Sure, thanks
Old Nov 10, 2018 | 12:16 PM
DannyJ's Avatar
I shoved a cork plug in the air tube going to cabin
the whistle is gone
Old Nov 10, 2018 | 08:05 PM
Queen and Country's Avatar
Thus the expression ' Put a cork in it will ya'
Old Feb 20, 2019 | 02:03 AM
DannyJ's Avatar
Default Solved
It was the alternator. There was no charge warning or so but at least on of the diodes was shot. Somehow the whining resonated into the cabin as it was under the dash.
Hope it will help someone
JagVonder
Oct 22, 2023 08:26 AM
aibeekay
Dec 8, 2019 08:36 PM
Verglace
May 16, 2013 08:59 PM
exrub
Oct 4, 2011 02:28 PM
