Will XK h&r springs fit the XKR ?
Old May 19, 2012 | 11:33 AM
TrexM3's Avatar
Default Will XK h&r springs fit the XKR ?
hey guys so id rather go with h&r over the mina springs . Are they dimensions different on the springs or just the stiffness? I cant seem to find much more then those options...
thanks in advance
Old May 19, 2012 | 03:41 PM
axr6's Avatar
thanks in advance
I suspect that they do but, I would recommend talking to the manufacturer before you buy. Make sure that you are getting the spring rates that you are looking for, be that primarily for ride comfort or stiffer track-style. Also, do dig around both Mina and H&R website as I seem to remember reading the claim from Mina that their spring rates were close enough to the OEM ones where no damper replacement would be needed. At the same time, if my memory is correct, the H&R website claimed that dampers do needed to be replaced with their stiffer springs. Needless to say, the cost differences of damper replacement vs. not alone could make you decide. If you do decide to replace the dampers make sure you know that you may be giving up the OEM electronic damper controls that, IMO, work darn well. Albert
Old May 30, 2012 | 10:30 PM
Chromey35's Avatar
I Too am looking at ordering springs and H&R website only has xk springs for 2007+ not xkr . I know people on here run H&R on there XKR so can someone perhaps let us know if those are the ones to order?
Old Dec 31, 2012 | 03:50 AM
Chromey35's Avatar
Bump sorry cant seem to see if this has been answered, I found a site with a good price but there for a xk only
bamforp
Aug 14, 2024 05:36 PM
08Z06
Oct 24, 2015 05:46 PM
EZDriver
Sep 8, 2015 09:25 AM
Tar
Sep 6, 2015 11:24 AM
TC Johnson
Sep 2, 2015 09:30 AM
