Window Reset Didn't Work
Old May 19, 2024 | 10:45 AM
justinhill's Avatar
Originally Posted by David993S
I sort of feel like we're going round and round on this topic. Multiple reset attempts did not work. I disconnected the battery for nearly 24 hours, reconnected it, did the reset procedure again multiple times.......still doesn't work. There is clearly something else amiss.
If anyone has a suggestion (other than more reset attempts or battery disconnect) on what is wrong, please let me know. I think someone mentioned a possible window module failure. Is that now the likely culprit? Can that be confirmed with a scan tool?
Cheers.
As I mentioned above, I have a persistent problem with one window which will one-touch up but not one-touch down. Since everything else works as it should (it's a convertible) I suspect it's a dodgy switch. If the switch is making an intermittent connection due to, say, dirt in the switch, it would appear to the car as if you were pressing and releasing the switch over and over (like a light flickering). I couldn't be bothered to investigate the issue on my car but if I did, I'd start by swapping over the switch connections between the right and left windows to see if the symptoms followed. Of course, I could be talking nonsense.
Mosin-Guy
Jan 7, 2024 12:20 PM
palmlakesman
May 5, 2022 09:22 AM
sailorbill
Jan 11, 2022 10:07 AM
Baxter3319
Jul 9, 2021 05:23 AM
mhminnich
Dec 31, 2020 07:40 AM
