Window switch doesn't work right
Old Sep 22, 2022 | 09:19 AM
TonyX's Avatar
Default Window switch doesn't work right
2007 XK convertible: driver side window switch doesn't fully work. One-touch up or down doesn't work. Holding switch up sends window up a few inches and it stops. It take about 6 switch activations to fully open or close the window.
I'm not sure where to start looking for issue. I tried window limit setting procedure several times with no change.
Old Sep 22, 2022 | 10:51 AM
panthera999's Avatar
Seeing you've tested the limit setting, it's a possible bad switch, motor or window regulator (the assembly that the motor uses to move the window). If you have an OBD that can trigger functions, you can test the switch by electronically triggering the window close. If it works, the switch is bad. If not, listen for a grinding noise as the window attempts to move. If so, bad regulator or motor. If I recall correctly, the limit is controlled by sensing current change in the motor when it reaches it's stops. So, something binding can cause the system to believe it's at a stop when it isn't.
Pull the door panel and watch what happens. Check the track or regulator mechanism for binding. Replacing a regulator and or motor is a pretty easy driveway job. Note that the door panel pins, being pretty old, may break as the panel is removed. Easy to slip new ones in place of the old. Typical, so you should be able to find replacements at your local NAPA.
Regulator/motor is one of those things you can comfortably get from a breaker, since it has no safety issue. Good luck.
Old Sep 22, 2022 | 11:03 AM
TonyX's Avatar
Thanks for the quick reply with your suggestions. I'll look into those things especially binding in the mechanism.
Old Sep 23, 2022 | 02:18 PM
lear60man's Avatar
My money is on the actual switch. If our switches are anything like other Euro cars, the internal grease turns to glue which attracts dirt and prevents contact. If you dont have a scanning tool handy, maybe you can swap switch panels from the other door.
But like Panthera said, listen for binding when going up and down.
palmlakesman
May 5, 2022 09:22 AM
10 XF Premium
Oct 11, 2018 11:03 AM
dickc
Jul 23, 2014 02:16 AM
Jsedita74
22
Jun 14, 2011 07:09 PM
johnpiero
Jan 24, 2010 11:38 PM
