Windsheild washer not working
Old Jan 12, 2014 | 02:45 PM
caryshaw's Avatar
Default Windsheild washer not working
Does anyone know how to change the washer pump on a 07 XK.
Old Jan 13, 2014 | 01:43 AM
Parzival's Avatar
if you get the workshop manual, its clearly explained in there.. think the manual would not be soooo expensive..
Its actually on the Right Front - under the RH Splash Shield
So you 'd need to jack your car, remove the wheel, remove the Fender Splash Shield
Then you will see to motors, the high-pressure headlights (optional) and the washer pump (84.10.21)
The washer pump is the smallest of the two..
(PS> Make sure you support the vehicle with enough stands, only a jack would be dangerous)
Old Jan 13, 2014 | 05:48 AM
caryshaw's Avatar
Thank you
Old Jan 13, 2014 | 06:07 AM
You don't have sufficient posts (minimum 10 required) to be able to download PDF's from the forum so here are the schematic and the washer pump removal pages from the Workshop Manual:
(click on the images to enlarge them)
Removal of the wing liner to access the pumps is straightforward.
Old Jan 13, 2014 | 06:32 AM
Parzival's Avatar
I could have gotten them for free?.. grumble.. I paid for them
Old Jan 14, 2014 | 06:07 AM
caryshaw's Avatar
Thank you
Forcedair1
Sep 8, 2025 01:57 PM
Bcrary3
Sep 12, 2021 05:41 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
al_roethlisberger
Sep 11, 2015 10:04 PM
philwarner
Sep 5, 2015 10:05 AM
