Won't start after inserting HT200 ODB reader
Old Jul 25, 2019 | 11:40 PM
scottjh9's Avatar
If you choose to change to a different reader, check out the icarsoft jaguar specific line....works both engine running or just in the on position.....I use the i930 model.....very nice unit
Old Jul 26, 2019 | 01:09 AM
Queen and Country's Avatar
Originally Posted by jag_man653
38 years working on my XJ-S
Wow that Jaguar XJS kept you young. I suppose there is always a brighter side to misery.
I am half your age and I cannot imagine being that advanced to get the latest code reader, app, and getting on forums in 45 years from now.
You are an inspiration. Thanks for showing us the future.
Old Jul 26, 2019 | 08:07 AM
jag_man653's Avatar
Not sure it was the Jag that's kept me going. I also spend lots of time writing software (see ConcoursBuilder.us) and hike about 15 miles per week.
Old Jul 26, 2019 | 08:11 AM
jag_man653's Avatar
Might do that.
I'm going to take it to a shop (Wilson Enterprises, Brea CA) early next week to see if they can sort it. When I talked to Jeff Wilson he said that some OBD2 devices don't do a good job of clearing codes.
Old Jul 26, 2019 | 08:18 AM
jag_man653's Avatar
Originally Posted by 110reef
Likely the brake pedal had pumped up so hard that you couldn't press it hard enough to activate the switch, and it couldn't start. Has happened before. After sitting overnight the pedal relaxed enough to activate the switch.
I did notice the brake pedal was very hard when it was in the non-start situation. What causes that? Pump running longer than it should due to fault pressure sensor?
Also, just what kind of a switch is it? I mean, if it was an old fashioned mechanical switch activated by the pedal I could understand that behavior. But I would think it's more likely a pressure switch in the hydraulics in which case the explanation doesn't make sense... to me anyway.
Old Jul 26, 2019 | 12:23 PM
Frank Sinatra's XJS ended up in Orange County, I was very close to buying it, there were just too many brokers involved.
Old Jul 26, 2019 | 09:30 PM
jag_man653's Avatar
Just looked at their website. Can't find any documentation. Is there a User's Manual? Don't want to try another device without careful reading of "what does what" and "what might happen".
Old Aug 12, 2019 | 03:48 PM
  #28
jag_man653's Avatar
Next episode.
The check engine light popped up again. Took it to the indie shop I've been using and they are now seeing:
P2406 Evaporative emission system leak detection pump sens - circuit high.
P0442 Evaporative emission system leak detected (small leak)
The tech says the pump has failed, verified by separate testing. Cost of repair, $462 labor + $262 parts. He also speculated that the the mandatory pre-sale smog test probably raised those codes too, and they just cleared them and sold the car. He said it just took some time or miles for the DTCs to be thrown again.
The car purchase came with a 50% parts 50% labor 30 day 1000 mile engine & tranny warranty, but I'll have to take it to them for the work.
trampintransit
Aug 28, 2018 05:09 AM
muskox3437
22
Apr 27, 2017 03:08 PM
overtheatlantic
Aug 23, 2013 11:19 PM
OldMike
Jun 16, 2012 04:31 PM
bigdollar
Sep 27, 2011 11:08 AM
