Wooden steering wheel on 07 XKR
Old Aug 3, 2013 | 04:05 PM
Marko's Avatar
Default Wooden steering wheel on 07 XKR
I used to have the heated/wooden steering wheel on my 07 XK, and miss it somewhat on my 07 XKR. Just called Jaguar, and they said there is no such option for my car. I could have sworn I read there is for the 07s, just not the newer ones. Can any of you shine some light on this?
And if there truly is no OEM option, any experiences with non-oem?
As always, any input is much appreciated!
Cheers,
Marko
Old Aug 3, 2013 | 04:50 PM
plums's Avatar
It might not be an option, but at a guess it is likely to fit.
Best source would be a junkyard or ebay.
If the parts book says the steering columns are the same number it's pretty much a given unless the switches on the wheel are different in function.
Old Aug 3, 2013 | 05:35 PM
u102768's Avatar
It is shown as an option in the brochures for an '07 XKR but you might not be able to easily retrofit the heated function.
Old Aug 5, 2013 | 06:26 PM
Marko's Avatar
Thanks to both of you! Strange that you see it as an option for the 07 XKR, but Jaguar said it wasn't. Maybe I had the wrong guy on the phone. I could live without the heat option.
Old Aug 5, 2013 | 09:22 PM
amcdonal86's Avatar
I, too, was surprised that it didn't come on the XKR. I actually didn't realize I didn't have that option until I drove it off the dealer lot. Then I sort of died a little bit inside.
But that's ok! It has things that I didn't expect, like adaptive headlamps!
Old Aug 5, 2013 | 11:39 PM
CleverName's Avatar
My IPB (I gave you a copy, right?) Shows the XKR with it(pg 62)...
Interesting to hear you miss it... Guess I would too....
Leather/Wood
Poplar C2P14949LEG $995.00
Walnut C2P14948LEG $995.00
Vince
Old Aug 6, 2013 | 02:43 PM
Marko's Avatar
Thanks all, I contacted another dealer. There is conflicting information out there.
@Vince: Yes, you gave me one. Thanks for reminding me, will check it out!
I keep you in the loop.
Marko
H20boy
Dec 24, 2024 03:23 PM
rusty37
Apr 5, 2020 07:40 PM
PMKimpton
Aug 3, 2019 08:22 PM
sogood
Sep 15, 2015 07:35 AM
AL NZ
Sep 4, 2015 08:39 PM
