X pipe drone question
Old Sep 30, 2023 | 01:30 PM
wymjym's Avatar
Default X pipe drone question
I have a NA 2008 XK. If driving in a civilized manner I can hear a deep exhaust sound between 1900~2200 rpm which I’m sure would be a pronounced drone if the mufflers were changed or deleted.
My question is, if I replace the front muffler with an X pipe affair, will this droning rear its ugly head when driving in this civilized manner?
wj
Old Sep 30, 2023 | 02:07 PM
sov211's Avatar
The annoying droning resonance on the 2007 and early 2008 cars was cured by an official Jaguar fix: a brace between the exhaust and the transmission casing.
Old Oct 1, 2023 | 05:51 AM
saajaguarx's Avatar
Hi Gregory,
Is this a brace that can be added to the ’07-’08 XK? I have searched for a brace and have not been able to identify this part. Do you have a picture or is it identified in any of the XK parts books?
Thank-you for any assistance available.
Old Oct 1, 2023 | 06:59 AM
kj07xk's Avatar
Originally Posted by saajaguarx
Hi Gregory,
I doubt if you can find the parts new anywhere now. But if you search this forum, there was a thread that discussed them (there are 2 braces, one mounted on each side of the transmission), along with drawings, such that you could fabricate your own.
Edit: See this thread, starting at post #42, for part numbers, pictures, drawing:
https://www.jaguarforums.com/forum/xk-xkr-x150-33/new-owner-introduction-165469/
Old Oct 1, 2023 | 11:22 AM
sov211's Avatar
Hi Gregory,
Yes it is, and I had my dealer fit the Jaguar fix to my 07 car. Instant cure for the droning.
Old Dec 1, 2023 | 03:10 PM
Wm. Lyon's Avatar
wj
I have a 2011, NA 5.0 XK and replaced the resonator with an X pipe. To me, it sounds way better across the rpm range, with absolutely no drone.
Old Dec 2, 2023 | 04:47 AM
guy's Avatar
guy
Coincidentally, I had installed the factory x pipe, in place of the centre resonator, then switched it back after the cats were changed.
Too rumbly all the time, especially on long drives.
asjdhsajhdfj
Nov 10, 2021 02:40 PM
Northern XF
Jul 30, 2017 09:03 AM
Evan Trinh
Feb 25, 2016 06:04 AM
jag01xk8
Mar 15, 2012 05:05 PM
MicksJag
Jan 31, 2012 02:51 AM
