XK coolant temperature sensor
Old Sep 18, 2021 | 08:16 AM
Ken D's Avatar
Default XK coolant temperature sensor
Is it possible to read coolant temp off a self installed gauge or the sensor is really a high/ low switch, like the oil pressure sensor?
Old Sep 18, 2021 | 08:35 AM
Addicted2boost's Avatar
The main coolant temperature sensor that’s located on the bottom of the thermostat housing (or just below it) on the front of the engine is where you want to tap into it. It’s just two wires and it definitely doesn’t act like a high/low switch like the oil pressure. You’ll get a live reading of the coolant temperature at all times.
Old Sep 18, 2021 | 09:46 AM
Cee Jay's Avatar
Easiest to read Coolant Temp from the OBD2 connector and a phone app. It's there and has all the info ready to go.
Old Sep 18, 2021 | 10:51 AM
bocatrip's Avatar
I think Ken D might want to read the temp on a permanent basis.
Old Sep 18, 2021 | 12:12 PM
Cee Jay's Avatar
Like this OBD2 fed info?...
Old Sep 19, 2021 | 03:56 AM
No Quarter's Avatar
I've got a chinese-cheapy HUD temp gauge reading off the OBD. Starts when engine starts, works fine. Easy
Old Sep 20, 2021 | 08:47 AM
gkubrak's Avatar
Im considering installing gages on the LH A-pillar, for oil pressure, battery voltage, and coolant temp. They make adapter kits for oil pressure. Not sure about the coolant temp since it doesn't screw into anything - but I'm sure it can be done, worst case you tap another hole into the coolant manifold. Or put it on the line that goes from the manifold to the expansion tank?
Running some wires through the firewall should be easy enough. Its been done before. And no need to plug up your OBD.
Old Sep 20, 2021 | 08:49 AM
gkubrak's Avatar
Something like this...
Old Sep 20, 2021 | 09:57 AM
Ken D's Avatar
[QUOTE=Cee Jay;2442925]Like this OBD2 fed info?...
How did you feed OBD 2 to get that display?
Old Sep 20, 2021 | 10:01 AM
Cee Jay's Avatar
[QUOTE=Ken D;2443646]
Torque Pro app loaded on an Android media box hooked to a GVIF.
Sean has the process in the thread searchable as something like "replacement of camp2" or something like that.
I usually have this displayed unless I'm searching for a specific track on my USB.
The Navigation directions are displayed on the miniscreen between the tach and speedo for using Nav anyway.
I just found it.....
https://www.jaguarforums.com/forum/x...-camp2-175877/
Old Sep 21, 2021 | 03:23 AM
JonWat's Avatar
Read this thread post number 19
Jagguyx300
Jan 15, 2021 05:59 PM
capnandy
May 10, 2020 05:03 PM
pnhb93
Nov 16, 2017 05:29 PM
oldmaned
Jun 21, 2014 09:19 AM
georgia boy
Jan 26, 2011 08:47 AM
