XK-RS - RS-seats lowering
Old Nov 15, 2013 | 05:29 AM
911's Avatar
911
Default XK-RS - RS-seats lowering
Gentlemen.
Dealer confused...
QUESTION: is it possible to lower RS-seats with saving electric seat regulation?
Old Nov 15, 2013 | 01:03 PM
Rw99's Avatar
Subscribed. I wouldn't mind an extra inch of headroom.
Rich
Old Nov 17, 2013 | 11:51 AM
Rey's Avatar
Rey
I'm a geezer who has modified many car seats, but my mods have been to raise the seats. This is easy, just takes shims and longer fasteners.
Lowering is more challenging. One thing any DYI car guy can do is cut out the carpeting that the seat tracks rest upon. This should lower the seats a bit. It also looks to me like the rear fasteners can be easily "adjusted" lower.
Next, I would shop around to find an auto hot rod uphostery shop that does custom work. Customizers do play with seat geometry. It may be tricky to retain all the seat movements. There may be other mfgs, like Corvette or Porsche, who have similar seat functions of more compact design.
Suggest you also query the vendors advertising in Jaguar World.
Old Nov 17, 2013 | 11:58 PM
911's Avatar
911
other problem is limited angle of the seat.
Old Nov 18, 2013 | 10:48 AM
Rey's Avatar
Rey
911: When you mention angle of the seat, I assume you are referring to the seat cushion as opposed to the seat back rest. As you know the seat back rest angle is controlled by the OEM seat controls.
The same controls can make your seat cushion virtually "flat", if that is what you want. But I sense you may want to raise the front of the seat cushion. That's easy: The seat is held to the frame by bolts at the front. Remove these bolts and insert shims (use "fender washers" available at most Ace Hdw. stores) to get the desired height. You may have to use longer bolts then, and Ace probably has them. My experience with our local Ace is that it has a huge assortment of fasteners, much more so than Lowes or Home Depot.
Old Mar 4, 2016 | 04:39 PM
Rw99's Avatar
I'm going to bump this thread to see if any members here have lowered the seat in their XKR/XKR-S... anyone?
Thanks,
Rich
SD96XJ6L
Dec 27, 2025 09:58 PM
tlynch
Dec 31, 2020 01:58 PM
Johnken
Apr 8, 2018 10:21 AM
MrWhite
33
Oct 22, 2015 10:29 AM
Delta66
Oct 4, 2015 05:40 PM
