XK transmission leak
Old Yesterday | 09:54 AM
framesynch's Avatar
Angry XK transmission leak
I own a 2007 XK which developed a little seeping around the lower pan 2 year ago. I replaced the pan oil etc and still leaked. This past winters cold the oil leaked out in a large puddle. I took it to a garage the specializes in older cars. They replaced the oil pan/oil etc and it’s leaking again. Is there another seal that I’m missing?
Old Yesterday | 10:13 AM
Cliffords's Avatar
The sump has a gasget or seal to the engine block . The sump also has a drain bolt with a washer/seal . There is a fill plug just above the sump on the side of the gearbox, part hidden and obscured on the XK by the exhaust. There is also a seal on the electrical connector to the box . A bit higher up the gearbox.
Can you smell the oil as gearbox oil . It does have a distinctive smell.
Old Yesterday | 01:28 PM
guy's Avatar
guy
A picture would be helpful.
mhamilton
Yesterday 02:00 PM
DonnyDB5
Dec 29, 2024 07:56 PM
Troy Thomas
Feb 25, 2023 03:03 PM
Ben Sawyer
Jan 12, 2017 10:19 AM
wukamury
Sep 21, 2012 01:43 PM
