XK / XKR Battery Overview and Replacement
Old May 7, 2014 | 01:25 AM
fma's Avatar
fma
Originally Posted by Ngarara
I put an Odyssey AGM battery in my XK8 about 3 years ago - no changes made to the electrical system or voltage regulation, but i had no problems with it.
Don't suppose you remember which Odyssey you put in? I'm getting conflicting info from the Odyssey dealer on the correct model, and being warned some "feteling" may be required!
Did find it interesting that the battery I took out tonight was the original from 2007 based on the date stamp and ~15k miles, so it served us well!
Old May 7, 2014 | 03:55 AM
Ngarara's Avatar
Odyssey PC1350, I believe. While I fitted it to an XK8 rather than an XK, it's the same one specified for the XK.
For the 4.0 XK8, the Odyssey was slightly shorter than the standard battery, and there wasn't enough thread on the vertical clamp rods to tighten the horizontal battery stay down. I used washers under the nuts to pack things up to the right height.
For your XK, I believe the battery is 2cm taller than the standard battery (check by measuring yours & comparing with the details on Odyssey's site) - from memory, the std. one is 17cm and the Odyssey is 19cm. However, someone has measured and there should still be clearance between the top of the battery terminals and the luggage area liner. The clamps on the XK hold the bottom of the battery, so the change in height isn't an issue for that, but someone mentioned using a strip of metal to pack the bottom clamps because of slight differences in width or depth.
Old May 9, 2014 | 07:51 PM
fma's Avatar
fma
Thanks, I ended up going with the Interstate AGM as it was available locally. Did notice the Interstate was a little taller than the original, and getting the battery in/out of the convertible is a bit of a pain (also needed to reset the top etc)
Old Aug 24, 2016 | 07:30 AM
Dr. Ray's Avatar
Default FIXED
Thank you everyone for all the info. Since I purchased my xk the touch screen has always been slow and freezes at least 3-4 times a month. I put a new bosch AGM in last week and the screen comes on immediately. So it was clearly a voltage issue.
Ray
Old Aug 25, 2016 | 08:08 AM
SickRob's Avatar
My battery died shortly after I bought the car in April. I called AAA and they installed a new battery for $182. Labor was free. I am a Plus member, but maybe that deal works for all members.
The tech did it in my driveway and then got in the car and reset all the items he was aware that needed resetting. Pretty good service I would say.
Two items he did not know about and I did not see mentioned here. The "service engine" light came on and the passengers seat back would not raise after being reclined. The dealer reprogrammed the seat at a cost of $130. Ouch!
The dealer also changed the oil, which was ok with me as I wasn't sure when it was last done. Now that I have seen the possible problem with timing chains and oil change frequency I'm very happy it was done.
Old May 19, 2017 | 05:24 PM
fma's Avatar
fma
Update - 3 years since I installed the Interstate AGM (kept on a tender when not in use) and zero electrical issues/gremlins with the car to date.
Old Jun 9, 2017 | 10:11 AM
Don-T's Avatar
I know it's an old thread but still useful. The question I have is: does the black cross brace between the wheel wells and directly across the bottom clamp need to be removed to pull the battery?
Old Jun 9, 2017 | 04:24 PM
  #28
Ranchero50's Avatar
No, but it's a pain to get the back facing battery retainer and primary wire retainers loose with it in the way. 10 mm everything to get it out.
Old Sep 12, 2018 | 09:31 PM
Kanwarpreet Baweja's Avatar
Thanks a bunch for the suggestions and advise guys.
And thumbs up to stillwaters for his help as outlined in the other batter-replacement thread (https://www.jaguarforums.com/forum/x...acement-54583/)
Here are a few things I learnt along the way,
1. had a kinda sorta backup battery purchased from Walmart laying around that I used , Maxx Everlast H8 , fits well- dont know how long it will last. Hopefully more than the last one since I plan on charging it once a week ( never charged the one I had before, used to leave car unlocked in garage, kids would go in and out of the car,sometimes turn the headlights on and stuff ...lol, all wrong stuff basically)
2.this time when the battery died, it really died , i mean wouldnt turn or click or do anything with the booster jumper . so, dead silence and no lights or horn with jumper cable still does not rule out battery discharge as the problem.
3.This one is really a question, I have a Black and Decker 10 amp car charger , will that work ok to provide weekly overnight juice ?
Old Dec 13, 2018 | 09:20 AM
  #30
Tandemcha's Avatar
Thanks for all of the helpful info. Replaced Jaguar (don't think it was the very original unit, but from 2013) battery with Bosch AGM. The Bosch unit is 1/2 inch taller but fit ok under the cover panel (tight but ok). Reset parking brake and windows and everything else the same except for trip data.
Old Dec 13, 2018 | 01:34 PM
  #31
Stuart S's Avatar
What is the Bosch AGM model number, cost, where did you buy it, and who installed it?
Old Dec 13, 2018 | 04:37 PM
  #32
sov211's Avatar
Well, yes...but what you really need is a CTEK battery maintainer permanently wired and to use it when the XK is not being driven. The connection time is about 4 seconds once you have permanently installed the wiring (and that takes 5 minutes). Use of this unit will eliminate any electrical issues caused by low battery voltage (and there are lots of those!)
Old Dec 13, 2018 | 08:16 PM
  #33
Tandemcha's Avatar
Pep Boys, Part#: 49-850BAGM, $176, just dropped it in myself.
Old Apr 28, 2019 | 05:19 PM
  #34
zealjag's Avatar
I replaced my battery yesterday and was following JeremyB's excellent instructions from 2011 and discovered a missing step.
In JeremyB's photos it shows a #3 but there is no mention of it in the description and this leads to an important step not being included making the removal more difficult if not done.
I have addressed this omission in the update below by adding a step 9A - see below.
7. Disconnect Negative terminal (10mm bolt) on the left. (#1 in the photograph)
8. Disconnect Positive terminal (10mm bolt). (#2 in the photograph)
9. Pull the vent tube off, and save for the new battery.
9A. Disconnect the cable that is across the base of the battery and attached to the retaining plate. This is done by inserting a small screwdriver between the plastic plug fitting and the holding plate #3 to release a clip then gently pulling the plastic plug fitting and cable away to the left of the battery. (When installing the battery, just push this plug fitting back into the holding plate after bolting on the retaining plate.)
10. Remove battery retaining plate (10mm security bolts x2) and swing aside. (#4 and #5 in the photograph)
Hope that helps
Old Apr 29, 2019 | 12:30 PM
  #35
Charghoul's Avatar
Great info thank you very much!
Old Jul 2, 2019 | 07:17 AM
  #36
Wullie Duff's Avatar
I Cant get number 4 nut out, or even get to it. Any ideas?
Old Jul 2, 2019 | 07:28 AM
  #37
Also, I don't see that black bar in your photo. Does it need to be removed?
Old Jul 2, 2019 | 07:46 AM
  #38
badicedog's Avatar
Thank you for sharing this.
Old Jul 20, 2019 | 09:47 PM
  #39
jag_man653's Avatar
Originally Posted by bobdr1
sam's club sells a 49AGM duracell battery for $159.99, I don't think it has a vent connection. Does AGM battery really need venting or are we just being overly cautious? Thanks for a great summary post!
I just bought a DuraCell AGM from Battery+ Bulbs. I asked the sales person if the unused vent on the other side needed to be plugged. He said No. Moreover, he said the neither hole went anywhere. There were there just to have a place to plug the vent tube into. The AGM batteries are sealed and therefore there's nothing to vent.
Old Jul 20, 2019 | 10:55 PM
  #40
badicedog's Avatar
Great post, thx for sharing
