XK / XKR Battery Overview and Replacement
Old Oct 21, 2025 | 04:21 PM
  #101
guy's Avatar
guy
Originally Posted by wymjym
My friends 545HP, E85, XE (which we got up to 169mph at the Texas Mile several years ago) has a LiFePo4. The only issue was that initially while being detailed the battery was 'killed'. It required a restore with a special charger. It is probably the way of the future. I'll stick with the old AGM and Older 2008 XK for a while!
wj
With that much horsepower, he had better not ever been late for work. Or he was wasting his money. If the battery can be connected to a car system and maintained with an alternator, I can’t understand why a special charger was needed.
One thing for certain I am very appreciative of this information. (And hate voice recognition)
Old Oct 21, 2025 | 05:22 PM
  #102
wymjym's Avatar
The voltage was like 7~8 volts. The detailer had the car several days, doors open. The battery was supplied with a charger for just such an occurance.
I guess a regular charger might have fried the BMS within the battery. The bat is guaranteed for 8 years. It is good now.
wj
Old Oct 21, 2025 | 06:48 PM
  #103
guy's Avatar
guy
wj
jeepers. That was expensive.
Old Oct 21, 2025 | 06:50 PM
  #104
guy's Avatar
guy
Originally Posted by Sean W
thx guy. I did a quick google search. This was the response. - “No, standard LiFePO4 batteries do not have a built-in DC-to-DC charger; this is a separate device that must be purchased and installed to charge them from a source like a vehicle's alternator. The DC-to-DC charger is crucial because it regulates the power from the alternator to prevent damage to both the battery and the alternator, ensuring a safe and efficient charging profile.”
Thanks @Sean W !
Old Oct 22, 2025 | 07:31 AM
  #105
ericmcn's Avatar
Chaps
These batteries. The Jaguar XK alternator is designed for bog standard SLA batteries with the specific charge profile. Be careful using any other type of battery, it's not necessary and there's plenty of good quality SLA types to use. Of course sales reps will flog you any battery it's their job to sell stuff.
In case anyone doesn't know replacing the Denso alternator is a pig of a job - I think LHD vehicles slightly easier for access due to the steering rack placement.
Old Feb 25, 2026 | 07:27 AM
  #106
mrhemi's Avatar
Recently purchased a 2008 XKR convertible. Making use of the forum for valuable information.
Regarding battery replacement (yes, working through the expected electrical gremlins), I find the spec battery for my car is a group 93, however it has a 6 year old group 49 (Interstate) installed. I notice that there are far more options for a group 49 battery and the newest versions seem to exceed the specs of a group 93. Is there any reason I should not substitute a group 49? No need to discuss wet vs. agm. I am familiar with that path.
Old Feb 25, 2026 | 07:43 AM
  #107
wymjym's Avatar
nope...it is a common replacement without issue.
WJ
Old Feb 25, 2026 | 08:36 AM
  #108
V7Sport's Avatar
yes, the group 49/H8 size works fine in my 2008 XKR. I have an Everstart AGM from Walmart with a 4 year warranty. A good value to me.
Old Feb 25, 2026 | 04:10 PM
  #109
kj07xk's Avatar
Group 49/H8 here as well.
Old Feb 25, 2026 | 05:10 PM
  #110
guy's Avatar
guy
And I'm the only one with the oem solution. Coincidentally, I'm also one of the few that does not keep the car on a maintainer and it sits fine, unused for 3 months at a time.
Old Feb 25, 2026 | 11:23 PM
  #111
bocatrip's Avatar
. That’s amazing! and you don’t disconnect the battery? What year XK? 3 months is Guinness Book Of Records for an XK.
Old Feb 26, 2026 | 07:58 AM
  #112
guy's Avatar
guy
I will always take a pint of Guinness. ;-)
No, I do nothing. As it is parked in my locked garage, I don’t even lock it.
But as a few now do, Since the ‘80’s I have always
1. From Aux to Start, I have always waited for all start up dings, chimes, whirs to stop before going start (including hearing a pressurization in the fuel system and awaiting the pump to shut off)
2. I always turn off every accessory before shutting down
3. And the moment the battery shows a continuous theme of holding a max 75% of spec’d capacity, replace it.
every sailor knows that there are drastic differences in the quality of a battery. You get what you pay for. Take a battery apart and look at the thicknesses of the plates. There is even a difference between OE quality and OEM quality on parts. It boils down to what is it you are comfortable on spending. And if the annoyances, annoy you.
Old Feb 26, 2026 | 03:07 PM
  #113
HealeyJag's Avatar
I'm jealous!!
Car Crazy
Oct 26, 2019 06:55 AM
potomacmidget
Jul 12, 2017 07:21 PM
06-XJR
16
Jul 5, 2016 11:13 AM
BlueXKR-S
Dec 5, 2013 09:27 AM
tosaman
Oct 15, 2010 06:12 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
