XK / XKR Battery Overview and Replacement
Old Aug 25, 2025 | 10:14 AM
  #81
miles61's Avatar
Old Aug 25, 2025 | 10:29 AM
  #82
wymjym's Avatar
If this one goes bad before warranty expires I'll do the lifepo4..
still have a 36v for my ebike, 7 years old and holding 90% charge!
wj
Old Aug 25, 2025 | 10:51 AM
  #83
Circumnavigator's Avatar
So I am curious.
When I had first starting reading as many threads as I could to learn while searching for my first x150…
The old debate was wet cell vs AGM mat (hush).
Seems that has been put to rest and AGM is fine, just have the Ctek that can do AGM, usually both.
This battery (linked above to Amazon) is Lithium Ion.
A whole different animal.
Has anyone successfully used a them for an extended period of time?
Do they require a new maintainer?
Old Aug 25, 2025 | 11:55 AM
  #84
wymjym's Avatar
Different beast, lifepo 4 vs lithium ion.
wj
Old Aug 25, 2025 | 11:57 AM
  #85
wymjym's Avatar
wj
Old Oct 18, 2025 | 09:09 AM
  #86
Pauldy's Avatar
A very good post but any further tips to # 11 “battery simply slides out, new one slides in” for a convertible? My replacement battery weighs 21.2 kg or 46.64pounds
Old Oct 18, 2025 | 09:16 AM
  #87
There are several good posts about that here, towards the end.
https://www.jaguarforums.com/forum/x...y-weak-292657/
Old Oct 18, 2025 | 06:17 PM
  #88
gbellefo's Avatar
A short piece of 1/2" plywood between the battery location and the edge of the trunk made installing my new battery very easy, just pushed it along.
Lifting it into the trunk is the toughest part.
Old Oct 19, 2025 | 09:59 PM
  #89
Speedmaster's Avatar
Originally Posted by miles61
I'm Taking a chance on a LIFEPO4 battery from Amazon, Amazon.com: LiFePO4 Lithium Car Battery, 12V 90AH 1300CCA Group 49 Starting-Stop Battery, Built-in Smart BMS, Perfect for Automotive Car, 60 Months Warranty : Automotive, I like the weight saving and Like CeeJay said I have also went thru 2 of the Duracell batteries.
Funny you should post this...my Duracell (I think) battery is showing signs of failure at the 4 year mark (now).
Are you suggesting this battery is a direct replacement? It looks much lighter and appears to have better stats (charge cycles, power loss, etc.)
Old Oct 19, 2025 | 10:09 PM
  #90
Stuart S's Avatar
I think you're looking for trouble with a lithium battery, as your alternator and Battery Monitoring System Module weren't designed for lithium batteries.
I wouldn't be able to sleep knowing there's a lithium battery in my garage. Or do they have to be at 30,000 feet to spontaneously combust?
Better safe than sorry.
Old Oct 20, 2025 | 07:52 AM
  #91
wymjym's Avatar
lifepo4 is not lithium ion! Lifepo 4 are safe.
wj
Old Oct 20, 2025 | 10:36 AM
  #92
KurtC's Avatar
...your alternator and Battery Monitoring System Module weren't designed for lithium batteries...
I notice that in SDD’s List of Personalization Parameters for Modification there is a line item titled, “Battery type”. Modification choices for this line item include proposed values of Undefined, Battery type 01 through 14, and Error (see picture below). My as-built value is set to Undefined. Does anyone know what the numerals 01-14 define or if changing to one of the numeric choices might be for AGM, Flooded, Lithium, etc., at differing amp-hour ratings such that the alternator would be properly regulated? When changing the battery in our former BMW, I could select battery type and amp-hour rating using their ISTA software, so am thinking maybe this is where such adjustments are made with a Jaguar. Any ideas?
Old Oct 20, 2025 | 10:09 PM
  #93
@Stuart S Quite a few NSX owners made the jump to lithium ion batteries (Shorai) as the weight savings was meaningful (from over 40# to under 10#). The issue was keeping them working as they seemed to fail over and over again. It could have been that we were using the smallest battery, intended for ATV use. Or, it could have been something else. But I never heard of any fires and with the prices on those cars skyrocketing, I am guessing if there were any issues word would have spread quickly. Anecdotal, sure. But, there you have it.
Old Oct 21, 2025 | 08:07 AM
  #94
wymjym's Avatar
Default Repeat!
The batteries are Lifepo4....they is safe.
They are not...Lithium Ion.
NOT LITHIUM ION.
wj
Old Oct 21, 2025 | 08:30 AM
  #95
guy's Avatar
guy
NOT LITHIUM ION.
wj
LOL… that’s how I feel some days.
Old Oct 21, 2025 | 01:47 PM
  #96
Sean W's Avatar
@KurtC what happens to the HEX values, the Block and bytes if you select any of the other battery Types? What version of SDD are you running? Great question. I suspect it's merely a place holder for future cars.
Old Oct 21, 2025 | 02:11 PM
  #97
Sean W's Avatar
NOT LITHIUM ION.
wj
Yep, sez it right in the name Lifepo - LI - Lithium, FE - Iron, PO - phosphate . Read up on these a while ago. They're not plug and play with our cars or really any conventional cars with an alternator. You apparently need a DC-DC charger placed between the battery and alternator. Only read about this. I don't have any direct experience.
Old Oct 21, 2025 | 03:09 PM
  #98
guy's Avatar
guy
I believe the “transformer” is within the case of the battery.
Old Oct 21, 2025 | 03:35 PM
  #99
Sean W's Avatar
thx guy. I did a quick google search. This was the response. - “No, standard LiFePO4 batteries do not have a built-in DC-to-DC charger; this is a separate device that must be purchased and installed to charge them from a source like a vehicle's alternator. The DC-to-DC charger is crucial because it regulates the power from the alternator to prevent damage to both the battery and the alternator, ensuring a safe and efficient charging profile.”
Old Oct 21, 2025 | 03:49 PM
  #100
wymjym's Avatar
My friends 545HP, E85, XE (which we got up to 169mph at the Texas Mile several years ago) has a LiFePo4. The only issue was that initially while being detailed the battery was 'killed'. It required a restore with a special charger. It is probably the way of the future. I'll stick with the old AGM and Older 2008 XK for a while!
wj
