XKR 2011 Camshaft Position Sensor Bank 1 Sensor B
Old Apr 3, 2022 | 09:29 AM
MintyJag's Avatar
Default XKR 2011 Camshaft Position Sensor Bank 1 Sensor B
Good morning!
Got a code for a bad Camshaft position sensor bank 1 sensor B.
Watched a video with a 2011 XF with the 5.0 non supercharged and they stated that bank 1 sensor B was on the passenger side closer to the center of the engine.
That is the sensor I changed. The check engine light has still remained but the car is no longer surging as it was before. Was this the correct sensor or did I replace the wrong sensor?
Thanks!
Old Apr 3, 2022 | 09:43 AM
panthera999's Avatar
You have two sensors on each side. See page 1680 in the 5.0 manual, page 1712 more or less for the codes and locations.
All have the same PN, so you can swap them position for position to see if that changes your symptoms.
Old Apr 3, 2022 | 10:49 AM
MintyJag's Avatar
FIrstly thanks for your response. I checked those pages it's not really telling me which sensor is which or what side each bank is on.
Old Apr 4, 2022 | 02:54 AM
There a diagram in Section 5. ENGINE of the XK/XKR - 'How To' / DIY Repair & Maintenance 'sticky' thread showing designation of Bank 1 and Bank 2:
https://www.jaguarforums.com/forum/x...enance-227403/
superv803
Feb 13, 2022 10:21 AM
Sid216
Dec 2, 2021 05:22 PM
machavaram
Nov 24, 2019 12:56 PM
Clamdigger
Feb 16, 2018 03:40 PM
StevenUSAnh
Nov 23, 2013 11:21 AM
