XKR-Rear toe adjustment bar replacement (Guidance needed)
Old Mar 10, 2018 | 04:27 PM
FrickenJag's Avatar
Former Sponsor
Default XKR-Rear toe adjustment bar replacement (Guidance needed)
I'm working on replacing a bent and worn rear toe bar on the 2008 XKR.
The work shop manual shows a nut, I have a bolt facing upward on my unit.
As I back the bolt out (Downward) it is pushing the upper segment away and deforming it. I'm not sure what I'm missing. The bolt isn't backing out, just unthreading itself from the top threaded segment. See photo.
Anyone run into this issue? I don't want to back out further as I'm afraid it may crack due to deformation or strip the threads.
The upper most part it is threaded into is the bracket which holds the e-brake mount for Alcon brake package.
Attached Thumbnails XKR-Rear toe adjustment bar replacement (Guidance needed)-toe-bar.jpg   XKR-Rear toe adjustment bar replacement (Guidance needed)-toe-bar-tech.png
Old Mar 10, 2018 | 04:44 PM
steve_k_xk's Avatar
First and foremost are you using a single hex socket to avoid stripping the bolt head and secondly is the park brake disabled
Old Mar 10, 2018 | 06:59 PM
FrickenJag's Avatar
Former Sponsor
Yes. Parking brake isn't disabled, didn't see that in the tech manual, and not sure how that would interfere but could try it.
Old Mar 10, 2018 | 07:29 PM
steve_k_xk's Avatar
The reason it is 'deforming' is due to the park brake holding the disc rotor
Release the park brake and it should be a fairly straight forward swap
Old Mar 11, 2018 | 12:08 PM
FrickenJag's Avatar
Former Sponsor
Thanks Steve. Didn't realize parking brake would inhibit removal.
Old Mar 11, 2018 | 04:23 PM
steve_k_xk's Avatar
No problems Derek
Happy wrenching !
chay
Sep 28, 2017 02:49 PM
Lannyl81
Mar 27, 2017 12:14 PM
plums
Jul 17, 2015 02:04 AM
jimlombardi
Nov 3, 2014 07:35 PM
Tijoe
Dec 18, 2012 08:21 PM
