XKR-S Wheel Spacers - Any pictures or specs?
Old Oct 2, 2022 | 10:29 PM
Jaggyx's Avatar
Default XKR-S Wheel Spacers - Any pictures or specs?
Hi all,
What wheel spacers do XKR / XKR-S owners run? 15MM? 20MM?
I can't seem to find this information readily available. I found the below picture from Bring a Trailer, but don't know the specs of the spacer.
Old Oct 3, 2022 | 03:24 AM
RichardS's Avatar
Doesn't it depend upon how far outwards you want to move the wheels?
Richard
Old Oct 3, 2022 | 07:58 AM
Jaggyx's Avatar
Richard
Correct. But there is usually a consensus on what's appropriate for these cars. I may pull the trigger on an XKR-S and am curious as to what others are running without rubbing.
Old Oct 3, 2022 | 09:01 AM
RichardS's Avatar
In that case I guess you must be referring to OEM standard rim offset and tyre sizes? I wouldn't have expected many owners to be fitting spacers in those circumstances but I stand to be corrected.
Richard
Old Oct 3, 2022 | 10:44 AM
Stuart S's Avatar
Wheel spacers aren't a good idea. But it's your car, your money, and your choice. Just know what can happen when you use them, which is why wheel spacers don't come from the factory.
https://www.jaguarforums.com/forum/x...A%2A%2A-76365/
Old Oct 3, 2022 | 10:54 AM
kj07xk's Avatar
As the first post in the above thread said, 20mm front, and 15mm rear, seems to be the common values used.
I have a set, had it for many years, but not installed, as I haven’t wanted to cut off part of the studs, yet.
Old Oct 3, 2022 | 11:53 AM
007XKR's Avatar
I agree with the 20mm front 15mm rear assessment. That is what I used and it does look better, in my opinion. No rubs, still turns just like it is supposed to. With 15mm, you do have to grind off the wheel stud a little bit, but not as far as the threads. There is a small section of unthreaded stud that keeps the spacer from making good contact with the hub. Remove most of that, and you are good to go.
Old Oct 3, 2022 | 12:40 PM
Cee Jay's Avatar
The only two problems with wheel spacers are excess wear on the axle bearings front and rear, and the front scrub radius will be off a bit.
Not huge problems, but they are actual.
I'd be fine with rear spacers.
BUT................
On the fronts, just get an extra set of matching rear wheels and put THOSE on the front with a 5mm spacer. They fit perfectly well. Sell the fronts for probably the same $$$ as you pay for two more rears.
ADDED BONUS... You can then rotate your tires!
Old Oct 3, 2022 | 04:16 PM
Jaggyx's Avatar
Thanks. I did the same when I had my F-Type so am familiar with the process. And pics of the stance on your ride with this setup?
Old Oct 5, 2022 | 03:21 PM
007XKR's Avatar
No, but I will pull it out of the garage later and take a couple of pics.
Old Oct 5, 2022 | 06:37 PM
guy's Avatar
guy
BUT................
I like the thinking. Is that what you've done?
Old Oct 5, 2022 | 06:44 PM
Cee Jay's Avatar
I HAVE put the rears on the front, and they do fit nearly perfect. Only bad part... I put the fronts on the rears for that moment because I can't find any Nevis Rears for an XK that aren't thousands of dollars per set. Thousands of Nevis rears for the XF, but they are the wrong offset.
SO, when I finally do find another set of rears that aren't crazy money, I will again have rears on the fronts and on the rears... until I get wider rear wheels of some sort.
FOR THE REARS....
Old Oct 5, 2022 | 11:56 PM
Jaggyx's Avatar
This is the setup on your XKR? Which wheels do you have? Wondering how different your offset is compared to the XKR-S wheels. And also, who makes 20MM front spacers? H&R only lists 15mm's.
Old Oct 6, 2022 | 01:01 AM
OzXFR's Avatar
I think there are a number of makers/suppliers of 20 mm spacers for modern Jags, one for sure is Teeze.
I have Teeze 15 mm front and 20 mm rear, great quality and zero problems after years on the car, see here:
https://www.aliexpress.com/item/3274...2-c19820e34402
Old Oct 6, 2022 | 07:48 AM
Jaggyx's Avatar
Thanks. I'll probably look for some spacers here in the States since the lead times on these seem to be far out. Just wanting to confirm that there's no difference in offset between an XKR and XKR-S factory wheels.
Old Oct 6, 2022 | 10:41 AM
007XKR's Avatar
Right after it was delivered, before spacers.
After spacers
Rear
Front
After spacers with the grocery-getter in the background.
Old Oct 6, 2022 | 11:19 AM
Canadacat's Avatar
I put 20's on the back left front alone , I like it but I am old so I lean a little to a muscle car stance.
Old Oct 6, 2022 | 01:11 PM
Jaggyx's Avatar
After spacers
Rear
Front
Looks great, but I belive the 4.2 and 5L had difference axel widths due to the e-diff in the 5.0 so 15mm for you might work for me, but I'm not entirely sure. Trying to get a 5.0 owner to chime in!
Old Oct 7, 2022 | 05:50 AM
guy's Avatar
guy
to each their own. the wheel extending beyond the lip of the fender cheapens the look to me…. again, to each their own.
Old Oct 7, 2022 | 07:10 AM
Canadacat's Avatar
Not in my eyes , the car doesn't look so much like a sebring anymore,
