Sponsored by: DashLynx
Xkr seat filter change HOW TO
Old 06-06-2016, 01:25 PM
bigdhenderson's Avatar
Default Xkr seat filter change HOW TO
Probably already a thread for this, but I just did this 5 minutes ago, and it took about 5 minutes to do.
I did this to see if the filter from the lincoln ls would work, and it does!
My model year is a 2010 XKR.
There are two tabs at the top (see pics) to pop out the outer cover. Then there will be two torx screws that have to be removed on the inner trim piece. Then twist out the old filter, twist in the new. Put it back together the same way it came apart. Pretty simple task.
I just couldn't justify what the dealer wanted for both the labor and the cost of the filter to do this. Some dealers include this in the standard mileage services but the one I went to in Denver last year didn't for some reason.
Old 06-06-2016, 01:27 PM
Old filter is the black one, new one (lincoln ls filter) is the new one.
Old 06-06-2016, 02:42 PM
tampamark's Avatar
Very cool, I will have to check mine. Is the black OEM filter media a carbon filter? If so I will just clean it instead.
Old 06-06-2016, 03:09 PM
Cee Jay's Avatar
Received 5,186 Likes on 3,106 Posts
Do you have any Part Numbers you could share with the rest of the class?
Old 06-06-2016, 06:41 PM
Ford part number is : 3W4Z19E880A
I don't believe it's a carbon filter. I think I actually like the white one better, after a few thousand miles I'll look at it and see if it's gotten very dirty. Hard to tell with the black one if it's doing anything.
I couldn't tell a difference after I did it, I don't think the one I pulled out was dirty.
The following 3 users liked this post by bigdhenderson:
Cee Jay (06-06-2016), Panthro (06-29-2016), robtroxel (06-21-2017)
Chuck Schexnayder
02-28-2021 10:27 PM
yidal8
05-02-2016 08:40 AM
coldpad1
04-28-2016 10:30 PM
raistlin295
04-21-2016 11:53 AM
U2vertigo1
04-04-2016 02:58 PM
Quick Reply: Xkr seat filter change HOW TO
