XKR Supercharger Isolator - Advice Needed
Old Aug 2, 2023 | 06:37 PM
mopars&jags's Avatar
Default XKR Supercharger Isolator - Advice Needed
Hello there, I'm seeking some advice. My 2011 XKR is currently at the dealer and the service advisor recommended I have the supercharger snout isolator changed. They quoted me $3800 for the job. My questions are, 1) Is this a repair that needs to be handled with urgency? If the isolator fails will it cause catastrophic damage? Can it fail? 2) How difficult would it be to replace this part myself? Does the supercharger need to be removed from the engine to perform this service? Thanks for any input and advice!
Old Aug 2, 2023 | 08:43 PM
Cee Jay's Avatar
Holy crap that's a ton of $$$ for that job.
One thing though, you don't have your location so nobody knows which continent upon which you reside.
The 5.0 liter is a bit more difficult than the 4.2 to do supercharger stuff as the throttle body needs to be removed to get to it, but it certainly isn't an almost $4k job. The hardest part would probably be checking/changing the SC oil as the filler/drain is at the rear of the supercharger.
The torsion isolator will make a clattering noise when it gets worn, but it isn't a blow-up-in-your-face problem. It should be fixed when it needs though.
The part is fairly cheap and the work is straightforward and shouldn't take more than a few hours. Any cost over $1000 I'd say is excessive.
Old Aug 2, 2023 | 08:55 PM
Okay I updated my location. Okay thanks for the information Cee Jay.
Old Aug 3, 2023 | 01:04 PM
bgpenguin21's Avatar
@Cee Jay you mentioned the torsion isolator making a clattering noise.. The SC on my 2010 XKR (~56,000 miles on the odometer) is also making a rattling noise. Sounds like a soup can rattling around inside a bigger coffee can (best way I can describe it). Could that be the same sound that you're describing? Trying to describe how each of us deciphers different sounds is one of the worst things about automobile troubleshooting isn't it? Anywho... I've been trying to track down this issue for a bit, and I'm wondering if this might be the culprit of the sound.
Old Aug 3, 2023 | 02:01 PM
Cee Jay's Avatar
Could be the isolator, the water pump, alternator, AIP or the AC compressor. The easiest way to see exactly where the sound is coming from is to place a long enough piece of wood (or some similar thing) against each part and also against your ear (protected by your hand) and it'll be obvious from where the sound is emanating.
Old Aug 3, 2023 | 02:03 PM
CA Jag's Avatar
Hey CeeJay, gotta raze you a little. CA is this side of the ocean altho where you're coming from, may need a passport. Thanks for your expertise in here. Jim
Old Aug 3, 2023 | 02:07 PM
Cee Jay's Avatar
BUT, since dude put that info in AFTER I stated such, it would have been a bit more difficult to ascertain that particular condition of presence.
How many oceans does the Earth have?
One, but it's just called different things in different places. It's all continuous and every body is accessible without touching land from every other body. Seas, however, usually necessitate using a canal or river-type thing to access.
Old Aug 3, 2023 | 02:24 PM
Thanks for the quick response @Cee Jay. Let's say that I establish that the sound is coming from the SC, would the sound that I described be inline with how the torsion isolator sounds when it starts going bad?
Old Aug 3, 2023 | 03:02 PM
Cee Jay's Avatar
Yes, instead of a steady hum noise there would be some rattle or even some knocking heard. Against an ear it will become very apparent if there is a 'bad' noise or not.
Gazinsky
Dec 20, 2022 03:00 AM
MoXKR
Jan 20, 2022 03:52 AM
TonyG1966
Oct 15, 2021 12:49 PM
HaydenS
Aug 5, 2017 09:22 AM
peterg19
Australia - Queensland
Feb 18, 2015 07:44 PM
