XKRS front bumper moulding problem
Old Apr 17, 2021 | 03:15 PM
Tafar's Avatar
Default XKRS front bumper moulding problem
I noticed this morning that the right wing of my XKRS called Molding Kit-C2P21969XXX had popped. It appears to be attached just by a double-sided tape and a fixing plastic pin. No screws or special fasteners.
I tried to reattach it from the inside. But after removing the front under-cover and the wheel cover, i cannot access to the fixing mechanism.
any idea to tight fix this element ?
Old Apr 17, 2021 | 04:10 PM
Cee Jay's Avatar
Amazon Amazon
Old Apr 17, 2021 | 04:13 PM
Tafar's Avatar
Thanks you but I assumed that there were screws or a fixing system and not only glue or double sided scotch
Old Apr 17, 2021 | 04:40 PM
Cee Jay's Avatar
Look at the other side, see what there is. You'd be surprised at how much goop, glue and tape manufacturers use now.
Old Apr 17, 2021 | 04:50 PM
Tafar's Avatar
I don't understand the purpose of these 2 holes and how to access the inner part of the bumper in order to attach the wing without removing the bumper itself.
Old Apr 17, 2021 | 05:01 PM
Cee Jay's Avatar
AH! I see...... one of the holes on your bumper has two sizes... put the pin into the large part of the slotted hole and push it forward so it locks into the smaller hole. Use some goop to hold the rest, as evidently the factory did because of all the residue still on the bumper. That DOES line up when in position, right? It's hard to tell from the photos.
Old Apr 17, 2021 | 05:17 PM
Tafar's Avatar
This photo is only for illustration. It's a wing of the left side. I flipped the photo to make easier to understand
The pin you show me goes on a simple hole with the same size. But you're right, there's another slotted hole facing the front hole of the wing (red arrow). And in this case I assume that a pin is missing here.
Old Apr 17, 2021 | 05:26 PM
Craniac's Avatar
3M Dual Lock is a velcro like product that is MUCH stronger than velcro. GM uses it to attach many trim parts. If all else fails, it may work for you.
Amazon Amazon
Old Apr 17, 2021 | 05:34 PM
Tafar's Avatar
Thanks but in this case I prefer windshield adhesive. It's stronger and it's a bit flexible. But before using it I ask only to know what is the factory solution.
Shagua
Apr 11, 2021 11:12 PM
kicknhard
Feb 6, 2020 01:05 AM
sherbercars
Apr 30, 2015 11:18 PM
sherbercars
Jan 10, 2015 03:05 PM
Need4Spd
Nov 23, 2011 05:33 PM
