Your opinions on the interior veneers
Old Apr 22, 2012 | 03:11 PM
aahmichael's Avatar
Default Your opinions on the interior veneers
As you know, in 2012, Jaguar changed the center console, and made the whole thing Piano Black. That means that that there are only a couple of places remaining for the wood veneers...a little piece behind the steering wheel, the panel above the glove box, and a tiny little square on each door.
Initially, I never considered putting anything other than wood in the XK that I have on order, because, after all, this is a Jag we're talking about. On top of that, I test drove an XKR that had the aluminum, and I felt it was very cold. It did absolutely nothing for me. So, my initial choice was the Figured Ebony, but then I realized that my other car (which I've had for a very long time) has basically the exact same Figured Ebony veneer in it, and I'm tired of it. So, I switched my choice to the Burl Walnut.
Now though, I'm having second thoughts about it, and I'm considering changing my choice to the Piano Black. On the plus side, it would bring unity to all of the shiny surfaces, but on the minus side, it would eliminate all wood from the interior...and the warmth that comes with wood.
So, what are your opinions? I'm guessing that some will say that a Jag has to have the warmth of the wood, while others might say that the wood makes the car look dated. I'm obviously on the fence right now, but I will say that by eliminating all the wood in the center console, Jag has essentially made the decision for me, because I think it looks silly not to have the dash match the center console.
It would be a completely different story if I was getting an XJ, because in that car, there is still that huge wood wrap around that exists. So, in that car, it doesn't matter that they changed the center console.
Thanks!
Old Apr 22, 2012 | 04:13 PM
Octurbo's Avatar
My Xkr-s has the optional piano black veneers on all surfaces. I really like it-it gives it a very clean and upscale look. Everyone who has seen the interior of my car has specifically commented on how they like this feature.
Old Apr 22, 2012 | 04:42 PM
HouTexJag's Avatar
+1 on the Piano Black. Like you said, it unifies the look. I also think that it is sportier looking than the grained woods and, after all, this is a very sporty car. I was also considering the aluminum, which is also sporty, but decided that the all piano black would look better.
I believe that the Piano Black trim is wood unlike the center console that is plastic like in my XJ. Is that correct?
Old Apr 22, 2012 | 05:15 PM
aahmichael's Avatar
I don't know if the center console is plastic. I'm sure someone with a 2012 will let us know. Even if it is plastic, and the trim is wood, the finish on both is high gloss, which should make them look basically the same.
Now that I think about it, though, it would be a huge disappointment if the center console is plastic. That would mean that they eliminated wood veneers for plastic in that entire area. Did Jag really do that?
Old Apr 22, 2012 | 06:13 PM
Bruce H.'s Avatar
My 2010 has the dark oak wood veneer, which is basically black to my eye, and coordinates very well with the black accents and charcoal interior that I have. I was not personally fond of the strong grained lighter wood veneers that I saw because they seemed out of place or too olde world in the XKR...or at least the image I had for mine. I have had the piano black finish in another vehicle for years, didn't like the bright aluminum, but the dark oak just suits me well.
I wouldn't expect to find concensous on colours and finishes, but you're sure to choose a combination you'll like!
Bruce
Old Apr 22, 2012 | 06:21 PM
aahmichael's Avatar
I really like that dark oak too, however, that finish is exclusive to the XKR.
Old Apr 22, 2012 | 07:24 PM
rscultho's Avatar
My 10 has Piano black center and Aluminum above dash and behind the steering wheel.
I am considering changing the Aluminum look to piano black so it will all be the same. In the XKR, I think (personally) that the black "fits" with the high end performance luxury "black tie" car that it is.
Now, in my wife's VDP, there should be wood and there will be wood. But that is a totally different kind of car, meant to convey a different context.
I had wood in my previous XKR's and wasn't sure I'd like them without it, but the Piano black looks good. I am living with the Aluminum until I change it out.
Old Apr 22, 2012 | 08:30 PM
mosesbotbol's Avatar
Are what exterior and leather colors are you looking for?
Old Apr 22, 2012 | 08:35 PM
Rahtok's Avatar
I'm with you aahmichael. It's a Jag. I passed over several cars due to piano black or aluminum. I have the Burl Walnut and love it. Mind you, mine's a 10, so it's got the Burl around the center stack as well. But... I simply love the Burl.
Old Apr 22, 2012 | 09:42 PM
Bruce H.'s Avatar
I've never seen that before...and it's gorgeous!
Bruce
Old Apr 23, 2012 | 04:47 AM
rscultho's Avatar
That is a beautiful color combination. I think the look of the wood is somewhat lost in the black interior, which is what I have. But for the caramel, ivory, and sandstorm interior's the wood is definitely a superior selection and look.
Old Apr 23, 2012 | 06:16 AM
aahmichael's Avatar
The caramel/burl combination that you have is classic and beautiful. Add in the fact that your center console is also burl, and it's an exquisite look.
My car is going to be ivory/charcoal. Plus I'm stuck with the piano black center, no matter what I put anywhere else.
Old Apr 23, 2012 | 10:04 AM
rscultho's Avatar
So I checked with the dealer, and the pieces above the steering wheel/below the instrument cluster area, and the piece above the glove compartment are $366.00 each.
They are held in by clips and are designed to "pop out" to be changed/installed.
Old Apr 24, 2012 | 05:11 PM
Stuart S's Avatar
Default Rich Oak Veneer Unique to 2009 Portfolio model
I thought y'all would like to see the Ivory seats, Slate dash, and Rich Oak veneer in my 2009 Portfolio:
Attached Thumbnails Your opinions on the interior veneers-pw_800%5B1%5D.jpg   Your opinions on the interior veneers-dash.jpg
Old Apr 24, 2012 | 06:45 PM
Rahtok's Avatar
Ooo -- I like that, Stuart.
Old Apr 24, 2012 | 09:12 PM
HouTexJag's Avatar
Good to know that you can probably change out the whole set, including door panels, for less than $1,500.
Old Apr 25, 2012 | 03:10 AM
Cadillac's Avatar
You can't go wrong either of these burl walnut or piano black . I dislike aluminum because it looks cheap even though the material itself don't suggest to me lol
Old Apr 26, 2012 | 01:48 PM
aahmichael's Avatar
Wow. It's amazing how just a few minor tweaks can change the entire nature of how a car looks. This is the XKR-S. Italian Racing Red. Sport Seats. Piano Black Veneer.
You would think you're looking at a Ferrari, not a Jag.
2012 Jaguar XKR-S Convertible….020 | Download Car Wallpaper
Old Apr 26, 2012 | 05:08 PM
HouTexJag's Avatar
Yeah, that looks really good--I'm definitely sold on the piano black. The only thing that would change my mind is if they offered a good quality carbon fiber for everything, including the center console. That would be extremely sporty.
Old Apr 26, 2012 | 05:38 PM
aahmichael's Avatar
I think that the contrast of the intense red against the black is what makes it so sharp. Although, here's piano black in an all-charcoal AM that looks really sharp too.
http://www.thesmokingtire.com/wp-con...or-cockpit.jpg
http://www.zcars.com.au/images/aston...-interior1.jpg
