XK120 XK140 XK150 1948 - 1962
Jaguar XK120 1954 - engine validation
Old Jun 14, 2023 | 01:05 AM
Rollin Dude's Avatar
Default Jaguar XK120 1954 - engine validation
Hello to everybody. Would need some help to identify the engine block of a clients jaguar XK120 from 1954. The engine was changed some years ago and is not the original one. The cylinder heads are coming from a c-Type Model but I´m not finding any information
about the engine blocks. I even git a picture from the client, the number shows 7167531-S or 7 I 67531-S. Is this number close to the gear bell the correct engine block number?
Maybe soneone can help. Thank you
Old Jun 14, 2023 | 07:59 AM
Coventry Foundation's Avatar
Are you sure it is not 7L? If so that is a 4.2 L engine not a 3.4 as the 120 would have had.
Old Jun 14, 2023 | 08:54 AM
I´m not sure, I guess it should be a 3.4 liter engine. Isn´t it that only c-heads were fitting on 3.4 liter engines?
Old Jun 14, 2023 | 10:20 AM
Correct but C type cam badges do not make it a "C" head. Look in the spark plug valley and see if there is a raised letter C. Also look in the area behind the distributor and you will see the engine size on the block. Jaguar did not start stamping the number on the flange until 1970.
Old Jun 14, 2023 | 10:29 AM
Thank you. Do you mean this number? V-1576-8
Old Jun 14, 2023 | 12:58 PM
Nope that is a head from a 3.4L XK150. Look beside the distributor on the block.It will say in raised letters what the displacement is. The head you show is def. not a 'C" head.
Old Jun 14, 2023 | 02:11 PM
ok, thanks. Will meet the owner tomorrow and will take a look!
Old Jun 14, 2023 | 02:24 PM
I have another question. In the homolgation papers is shown an engine number like this: B2329/8. As I found out this could be a number from a MK7 from 1950 to 1954 ?
Old Jun 18, 2023 | 01:57 PM
It is 4.2 litre block. The number on the block shows F245 too. Is this any other identification number?
You mentioned to search for a C Letter on the head. Here are some pictures. Is this the code for a c-type head?
GC 479 on the top and C 2153 at the backside.
Old Jun 19, 2023 | 07:24 AM
No you would see a large raised 'C' in the middle of the head. You have a real challenge on this one--sort of a bitsa. Even the bolts are a mixed bag--note the metric bolt in your pic. Best of luck!
Old Jun 28, 2023 | 12:34 PM
Do i find any information the "-S" on the head stands for (V-1576-S")? If I take a look at https://www.jag-lovers.org/xk-lovers...y/engines.html
I don´t find any information about the ending with -S.
Old Jun 29, 2023 | 01:08 PM
That is most likely an 8 not an S which stands for 8 to 1 compression.
jaguar1966$
E type ( XK-E )
Feb 10, 2023 09:20 AM
peckhs
General Tech Help
Oct 13, 2021 05:33 AM
Rwc13
Mar 20, 2020 04:53 PM
jasonpeisl
XK120 XK140 XK150
Nov 28, 2019 05:27 PM
hooperdoski
Jun 10, 2009 12:28 PM
