XK120 XK140 XK150 1948 - 1962
New member - Needs Help
Old Jun 23, 2013 | 08:23 PM
400iguy's Avatar
Question New member - Needs Help
Hi. I'm new here. See the URL below:
https://www.jaguarforums.com/forum/n...rophead-97549/
My current (first!) problem with the Jag is the trunk doesn't unlatch. The car has extensive manuals and service records. I could use them to try and figure out a fix for this BUT all the doc is in the trunk!!!!!
The button will push ok and some times the passenger side corner comes up a half inch or so. From this I can tell tell it latches at each corner. I can see there is a cable involved.
Any suggestions?
Al
Old Jun 24, 2013 | 02:37 PM
Al,
These pics of the lock components may help you figure out how to release it:
It looks to be a single cable with adjuster going to each of the two corner locks. Possibly one or both cables have too much slack to pull the blocks?
Old Jun 25, 2013 | 09:34 AM
400iguy's Avatar
Thanks for the photos That helps a lot. I can just see the cable and pulley on the passenger side. I was hoping I could pull on that cable to release the other side. I can clearly see from the photos that won't work.
Al
Old Jun 25, 2013 | 10:13 AM
Al,
The simplest way could be to drill a small hole directly above the driver side lock and flip the pulley open with a rod through the hole as a lever. Filling and refinishing the hole is a pain but a lesser risk than possibly distorting the trunk lid trying to get to it from the slightly raised passenger side.
Old Jun 25, 2013 | 11:22 PM
Jagfixer's Avatar
We used to remove seats and open compartment from interior and remove hardura on boot lid and remove handle bolts from inside, open and fix.
Old Oct 12, 2015 | 11:55 AM
Jeronimo770's Avatar
Originally Posted by GGG
Al,
Neither this, nor trying to remove the lid lining/card/Hardura is feasible in the DHC's.
See here for how I solved this problem.
https://www.jaguarforums.com/forum/x...3/#post1326561
trickeyM
Oct 4, 2015 05:43 PM
Clare Jennings
rhemler
Oct 4, 2015 05:37 PM
Spazzzzzzzzzy
Newark Nj Gang
Oct 2, 2015 02:39 PM
