XK120 XK140 XK150 1948 - 1962
XK120 Roadster (1954) Horn Assembly
Old 07-01-2018, 02:17 PM
ETypeDave's Avatar
Default XK120 Roadster (1954) Horn Assembly
I have a loose horn assemble within the steering wheel. Bounces around now. Can anyone inform me the steps to remove the horn button, ect., so as to tighten whe assembly within the steering wheel?
many thanks in advance!!
Old 07-01-2018, 05:51 PM
George Camp's Avatar
Dave look for the grub screws that hold the assy. in. Perhaps you just need to tighten them. Do you have a WSM?
Old 07-01-2018, 06:42 PM
ETypeDave's Avatar
Hi George,
do do not have the WSM. Question, is the horn button held in place with spring clip type fingers, so it can be removed by prying?
Thanks!
Old 07-01-2018, 06:52 PM
ETypeDave's Avatar
Pardon the poor english... I do not have a WSM. There are two set screws (outside of steering wheel base, interior to wheel spokes), which are slotted pointed set screws. Are these the "Grub Screws" or are the "Grub Screws" internal (steering wheel hub)?
Thanks!
Old 07-02-2018, 05:32 AM
Those are the grub screws---back them out and you can remove the horn assy. Do not pry anything--you will regret it $$$$$!
Old 07-02-2018, 10:48 AM
ETypeDave's Avatar
Thanks!
Sean W
11-13-2020 08:04 PM
salmeronj85
XK120 XK140 XK150
06-13-2016 09:01 AM
yyzjag
XK120 XK140 XK150
06-28-2015 09:23 AM
jakeperigo
XK120 XK140 XK150
04-18-2015 02:07 PM
jakeperigo
XK120 XK140 XK150
06-19-2014 12:01 PM
Quick Reply: XK120 Roadster (1954) Horn Assembly
