XK120 XK140 XK150 1948 - 1962
Remove wheel cap on 1950 XK 120
Old Aug 20, 2023 | 11:49 AM
stoutd47's Avatar
Default Remove wheel cap on 1950 XK 120
How do you remove the center wheel cap on a XK 120? Do you just use a screwdriver or crow bar and just pop it off?
Old Aug 21, 2023 | 05:14 AM
Welcome to the forums stoutd47,
Presumably this is the chrome cover (item 3) on a steel wheel (item 1) and not the two or three eared spinner (item 11) on a spoked wheel (item 6)?
If so, there is a Jaguar tool for this (P/N C26864) but it is only a flat bar bent over at the end. A large flat blade screwdriver will do the job although wrapping the end in electricians tape will prevent scratches.
If you want the genuine tool, here's a supplier in the UK with a useful photo:
http://coventryautocomponents.co.uk/...tool%20-c26864
You could use the P/N to find a supplier in the USA or the photo to replicate the tool from flat bar.
Please read the guidance for new members ( https://www.jaguarforums.com/forum/n...ned-up-241802/ ) which answers many of the most frequent questions about getting started on the forums.
Old Aug 21, 2023 | 07:04 AM
stoutd47's Avatar
Thank you Graham. I just purchased the car so as I learn more about the car I suspect I will be posting more questions.
retroren
Mar 4, 2022 09:41 AM
92/93 XJS
Nov 5, 2020 07:06 PM
2004XJ8
Jul 12, 2020 10:37 PM
James O
Jun 8, 2017 05:05 PM
Hafrod
Feb 11, 2016 11:42 PM
