XK120 XK140 XK150 1948 - 1962
Weight of an XK 3.4L engine
Old Mar 17, 2018 | 05:08 PM
rjaguarmk1's Avatar
Default Weight of an XK 3.4L engine
What is the Weight of an XK 3.4L engine?
Old Mar 17, 2018 | 06:07 PM
Fraser Mitchell's Avatar
I'm not sure, but engine and gearbox on my old Series 3 was about 600 lbs I think. Certainly if you're doing any lifting of it you need to make sure the tackle can handle this sort of weight. Heavy duty engine stand is also a must if your rebuilding the engine. There is a lot of weight there !
Old Mar 17, 2018 | 06:32 PM
rjaguarmk1's Avatar
Smile Weight of an XK 3.4L engine
Thanks for the reply. I got tired of looking around elsewhere and not finding any details about engine weight, so I tried the Jaguar Forum and got the answer! Yes, the XK engine is heavy, having changed one before. Just wanted to confirm just how much it weighs. Looking forward to Spring weather to tackle a rebuild.
Old Mar 18, 2018 | 04:31 AM
When I had to lift out engine and transmission in the early 90s I made sure I checked-out the weight. In my case it was to replace the block as mine was cracked. This started over 2 years of work on the car ! One job just leads to another - "engine's out so I'll tidy up the engine compartment, oh, those wings don't look good, my God, sills are on the way out........."
carsnplanes
Jul 29, 2022 02:19 PM
IB Nolan
I-Pace EV
May 20, 2018 08:08 PM
whitbyxf
XF (X260)
Feb 21, 2018 04:38 PM
sogood
Jan 25, 2018 09:09 PM
superchargedtr6
Dec 25, 2017 08:07 PM
