XK120 XK140 XK150 1948 - 1962
XK120
Old Apr 13, 2020 | 09:27 PM
SoSlow's Avatar
Default XK120
What batteries are available for the xk120 battery boxes behind the seats in my 1953 FHC?
Old Apr 14, 2020 | 06:51 AM
Fraser Mitchell's Avatar
Does yours still have the two 6 volt batteries fitted ? Most people convert to a modern compact 12v battery that fits one of the holders. I can't tell you what size is available, sorry.
You can still get the original 6v type as well.
https://www.scparts.co.uk/sc_en/brit...-fittings.html
Old Apr 16, 2020 | 07:13 PM
SoSlow's Avatar
Default XK120 Batteries
I don’t have batteries at the moment. Every 10 years or so I replace all the fluids and drive for about 10 miles or so. The batteries used to die quickly even later when I used a battery maintainer.
So looking for a more modern battery; either 2 six volts or 1 or 2 12 volts that fit in the boxes.
Car info: 43K miles about 98% untouched. 8:1 compression motor.
Old Mar 18, 2021 | 10:11 PM
SoSlow's Avatar
Default Perfect fit batteries
Found perfect fit battery for the XK120 behind the seat boxes. At Tractor Supply of all places. Only needed one 12 volt as it turns the car over fine.
Pic of my Grandmother on the Jag back in the day.
Old Mar 23, 2021 | 07:41 PM
sov211's Avatar
A great photo of both!
Old Aug 19, 2021 | 03:49 PM
Rick W's Avatar
I have a 1954 XK120 OTS and use a single Mazda Miata 12 volt battery. Not a lot of cranking power but does the trick. I run my car in the winter and it struggles to turn over but fires up. I keep a charge on it in the winter to have maximum capacity.
Jaaager
Oct 7, 2019 01:40 PM
badboyauto
Aug 4, 2017 04:06 PM
amcdonal86
Mar 1, 2016 01:28 PM
rtcosic
Feb 29, 2016 06:13 AM
JagStagMagBlagHag
Interior
Feb 5, 2008 06:51 PM
