XK120 XK140 XK150 1948 - 1962
XK120 Speedometer
Old May 6, 2019 | 05:31 PM
georgeryoung's Avatar
Default XK120 Speedometer
I'm trying to determine how to figure out what's going on with my Speedometer. I'm going to detach the speedo cable from the meter and have someone check to see if the cable is rotating. Years ago I had the unit repaired I can
t remember if it was rebuilt at that time. That was back in 1979. The odometer isn't registering and the speed is at Zero. Any suggestions?
Old May 7, 2019 | 06:08 AM
Fraser Mitchell's Avatar
The first check you're already doing, which is to check the drive cable is rotating. If it isn't, it could be broken, or the little drive gear at the gearbox end has failed. If the drive cable is OK then it's time to delve inside the speedometer.
r0m8470
Photography
Mar 3, 2013 09:53 PM
Francis THIBAUD
XK120 XK140 XK150
Apr 4, 2011 05:46 PM
Homsangpradit
XK120 XK140 XK150
24
Mar 26, 2011 11:38 PM
susu
Feb 15, 2011 12:58 AM
mrelezaj
Aug 23, 2010 05:59 PM
