XK120 XK140 XK150 1948 - 1962
XK140 Roadster Body chassis interface
Old Jan 20, 2016 | 04:53 AM
Atco's Avatar
Default XK140 Roadster Body chassis interface
I have recently bought a 55 roadster in bits! The car has had a lot of work done. Does anyone know where I can get info on how to shim/mount the body on the chassis. There are several of the aluminium distance pieces with the car and I believe these had a fibre washer between the Aluminium and the steel to discourage electrolytic corrosion at the interface.
Were all the bodies mounted off the chassis to the same height?
I don't want dimensions from the road to the body as the body is bare and therefore lighter than when in full road trim. The car was LHD and I am building it up as RHD. Chassis number 811403.
Kind regards
Charles
Old Jan 22, 2016 | 05:18 PM
Fraser Mitchell's Avatar
I see nobody has input on this, so here is my penn'orth.
Yes, you need some sort of barrier between aluminium and steel to stop the aluminium acting as a sacrificial anode to the steel and gradually disappearing as dust ! I would use a more modern material than fibre washers which can absorb water.
As for actually mounting the body, I had a quick look at the parts pictures and saw nothing for body mountings. You need to search for an XK specialist in the UK, there are a few around.
Old Jan 25, 2016 | 02:08 AM
Atco's Avatar
Thanks. The E type w/s manual contains copious amounts of body ride height info. But alas nothing for the 140. I will keep hunting and asking around.
LedZepplin
Jun 17, 2016 12:12 PM
Clasico
Jan 23, 2016 07:41 AM
jaggedconvert
Jan 19, 2016 01:33 AM
allnlu
Europe
Jan 18, 2016 05:39 AM
powerhouse
Jan 16, 2016 09:19 AM
