Complete List of All OBD Codes
Old Nov 4, 2010 | 10:33 PM
Reverend Sam's Avatar
Default Complete List of All OBD Codes
I got this list from here. I think it's a complete list, but if it's not, please add any codes that you are aware of.
I noticed that there wasn't a list of codes in the FAQs. I think this would be a helpful addition.
P1000 OBD Systems Readiness Test Not Complete
P1104 Mass Air Flow Sensor Circuit Ground - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1111 System Pass
P1121 Pedal Position Sensor A Circuit Range/Performance
P1122 Pedal Position Sensor A Circuit Low Input
P1123 Pedal Position Sensor A Circuit High Input
P1136 Control Box Fan Circuit - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1137 Lack Of HO2S12 Switches - Sensor Indicates Lean - Read Our Article on Oxygen Sensor Codes For Help With This Jaguar Check Engine Light Code
P1138 Lack Of HO2S12 Switches- Sensor Indicates Rich
P1143 Air Assisted Injector Control Valve Range/Performance
P1144 Air Assisted Injector Control Valve Circuit - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1157 Lack Of HO2S22 Switches - Sensor Indicates Lean - Read Our Article on Oxygen Sensor Codes For Help With This Jaguar Check Engine Light Code
P1158 Lack Of HO2S22 Switches - Sensor Indicates Rich
P1171 System Too Lean- Banks 1 And 2 (Lean Fuel Fault)
P1172 System Too Rich - Banks 1 And 2 (Rich Fuel Fault)
P1174 System Too Lean - Banks 1 And 2 (Suspect HO2S)
P1175 System Too Rich - Banks 1 And 2 (Suspect HO2S)
P1176 Long Term Fuel Trim Too Lean - Banks 1 And 2 (FMFR) - Read Our Article on Oxygen Sensor Codes For Help With This Jaguar Check Engine Light Code
P1177 Long Term Fuel Trim Too Rich - Banks 1 And 2 (FMFR)
P1178 Long Term Fuel Trim Too Lean - Banks 1 And 2 (AMFR)
P1179 Long Term Fuel Trim Too Rich - Banks 1 And 2 (AMFR)
P1185 O2 Sensor Heater Circuit Open - Hardware Fault
P1186 O2 Sensor Heater Circuit Shorted- Hardware Fault
P1187 O2 Sensor Heater Circuit Open - Inferred Fault
P1188 O2 Sensor Heater Circuit Resistance
P1189 O2 Sensor Heater Circuit Low Resistance Fault 1
P1190 O2 Sensor Heater Circuit Low Resistance Fault 2
P1191 O2 Sensor Heater Circuit Open - HArdware Fault
P1192 O2 Sensor Heater Circuit Shorted
P1193 O2 Sensor Heater Circuit Open - Inferred Fault
P1194 O2 Sensor Heater Circuit Resistance Fault
P1195 O2 Sensor Heater Circuit Low Resistance Fault 1
P1196 O2 Sensor Heater Circuit Low Resistance Fault 2
P1198 Fuel Level Input Circuit High
P1199 Fuel Level Input Circuit Low
P1201 Cylinder # 1 Injector Circuit Open/Shorted - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1202 Cylinder # 2 Injector Circuit Open/Shorted
P1203 Cylinder # 3 Injector Circuit Open/Shorted
P1204 Cylinder # 4 Injector Circuit Open/Shorted
P1205 Cylinder # 5 Injector Circuit Open/Shorted
P1206 Cylinder # 6 Injector Circuit Open/Shorted
P1207 Cylinder # 7 Injector Circuit Open/Shorted
P1208 Cylinder # 8 Injector Circuit Open/Shorted
P1221 Pedal Demand Sensor B Circuit Range/Performance
P1224 Electronic Throttle Control Position Error
P1226 Mechanical Guard Circuit Range/Performance
P1227 Mechanical Guard Circuit Low Input
P1228 Mechanical Guard Circuit High Input
P1229 Electronic Throttle Control Circuit
P1230 Fuel Pump Relay
P1235 VSV 1/2/3 Circuit Range/Performance - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1236 VSV 1 Circuit
P1237 VSV 2 Circuit
P1238 VSV 3 Circuit
P1240 Sensor Power Supply
P1241 Sensor Power Supply Low Input
P1242 Sensor Power Supply High Input
P1243 Analog Ground
P1245 Crank Signal Low Input
P1246 Crank Signal High Input
P1250 Throttle Valve Spring
P1251 Throttle Position
P1252 VSV Stuck On VA/VV
P1253 VSV Stuck On VR
P1260 Theft Detected, Vehicle Immobilized
P1313 Misfire Rate Catalyst Damage Fault - Bank 1
P1314 Misfire Rate Catalyst Damage Fault - Bank 2
P1315 Persistent Misfire
P1316 Misfire Rate Exceeds Emissions
P1336 Crankshaft/Camshaft Sensor Range/Performance
P1340 Camshaft Position Sensor B Circuit - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1341 Camshaft Position Sensor B Circuit Range/Performance
P1361 Ignition Coil, Cylinder # 1, No Activation
P1362 Ignition Coil, Cylinder # 2, No Activation
P1363 Ignition Coil, Cylinder # 3, No Activation
P1364 Ignition Coil, Cylinder # 4, No Activation
P1365 Ignition Coil, Cylinder # 5, No Activation
P1366 Ignition Coil, Cylinder # 6, No Activation
P1367 Ignition System Failure Group 1
P1368 Ignition System Failure Group 2
P1370 Insufficient RPM Increase During Spark Test
P1371 Ignition Coil - Cylinder 1 - Early Activation Fault
P1372 Ignition Coil - Cylinder 2 - Early Activation Fault
P1373 Ignition Coil - Cylinder 3 - Early Activation Fault
P1374 Ignition Coil - Cylinder 4 - Early Activation Fault
P1375 Ignition Coil - Cylinder 5 - Early Activation Fault
P1376 Ignition Coil - Cylinder 6 - Early Activation Fault
P1384 Variable Valve Timing Solenoid A Circuit - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1392 Variable Valve Timing Solenoid A Circuit Low Input
P1393 Variable Valve Timing Solenoid A Circuit High Input
P1396 Variable Valve Timing Solenoid B Circuit
P1397 Variable Valve Timing Solenoid B Circuit Low Input
P1398 Variable Valve Timing Solenoid B Circuit High Input
P1400 Exhaust Gas Recirculation Valve Postion Control
P1401 Exhasut Gas Recirculation Valve Postion Circuit
P1408 Exhaust Gas Recirculation Thermister
P1409 Exhaust Gas Recirculation Valve Circuit - Read Our Article on EGR Valve Codes For Help With This Jaguar Check Engine Light Code
P1440 Purge Valve Stuck Open
P1441 ELC System 1
P1447 ELC System Closure Valve Flow
P1448 ELC System 2
P1453 Fuel Tank Pressure Relief Valve Malfunction
P1454 Evaporative Emission Control System Vacuum Test
P1475 Fan Relay (Low) Circuit
P1476 Fan Relay (High) Circuit
P1508 Idle Air Control Circuit Open
P1509 Idle Air Control Circuit Shorted
P1514 High Load Neutral/Drive Fault
P1516 Gear Change Neutral/Drive Fault
P1517 Cranking Neutral/Drive Fault
P1534 Restraint Deployment Indicator Circuit
P1565 Speed Control Command Switch Out Of Range High
P1566 Speed Control Command Switch Out Range Low
P1567 Speed Control Output Circuit - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1568 Speed Control Unable To Hold Speed
P1571 Brake Switch
P1582 Electronic Throttle Monitor Data Available
P1600 Loss Of Kam Power, Circuit Open
P1603 EEPROM Malfunction
P1605 Keep Alive Memory Test Failure
P1606 ECM Control Relay Output Circuit
P1607 MIL Output Circuit
P1608 Watchdog Malfunction
P1609 Internal Control Module CPU To CPU Communication Failure
P1611 Throttle Target Malfunction 1
P1612 Throttle Offset Malfunction
P1637 CAN Link ECM/ABS Control Module Circuit/Network
P1638 CAN Link ECM/INSTM Circuit/Network
P1641 Fuel Pump Primary Circuit
P1642 CAN Link Circuit
P1643 CAN Link Engine Control Module/Transmission Control Module Circuit/Network
P1646 Linear O2 Sensor Control Chip (Bank 1)
P1647 Linear O2 Sensor Control Chip (Bank 2)
P1648 Knock Sensor Input Chip
P1696 CAN Link Engine Control Module/Cruise Control Module Circuit/Network
P1697 Cruise Control Distance-Control Input Circuit
P1700 Transmission Indeterminate Failure (Failed To Neutral)
P1720 Vehicle Speed ( Meter) Circuit
P1722 Stall Speed
P1726 Engine Overspeed
P1730 Gear Control Malfunction 2,3,5
P1731 Inconsistent Gear Ratio
P1734 Gear Control Malfunction
P1745 Pressure Regulator 1
P1746 Pressure Regulator 2
P1747 Pressure Regulator 3
P1748 Pressure Regulator 5
P1758 Pressure Solenoid Control System Incorrect Current
P1775 Transmission System MIL Fault
P1776 Ignition Retard Request Duration
P1777 Ignition Retard Request Circuit - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1778 Transmission Reverse I/P Circuit
P1779 Load Control
P1789 Ignition Supply Malfunction
P1790 Ignition Supply Malfunction
P1791 Ignition Supply Malfunction
P1792 Ignition Supply Malfunction
P1793 Ignition Supply Malfunction
P1794 Battery Voltage Circuit
P1795 Inconsistent CAN Level
P1796 CAN Controller Circuit (Bus Off)
P1797 CAN TCM/ECM Circuit Malfunction - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1798 CAN TCM/INST Circuit Malfunction
P1799 CAN TCM/ABS Circuit Malfunction
P1882 Engine Coolant Level Switch Circuit Short To Ground
Old Nov 5, 2010 | 12:28 AM
avos's Avatar
There are some small changes per model year, so best is always to check yours. I think on most JTIS cd's you will find the DTC list per model&year.
Old Nov 5, 2010 | 07:26 AM
steve11's Avatar
ud
Yep - agree - Lists like this have to be model AND MY specific. These charts are published in the JTIS by both model and MY. Some codes on a generic list like this won't work for the X-Type, for example. There are two big crossovers for codes and other OBD information on the AJV8s - one at the AJ26/27 and one at the 4.0/4.2.
Additionally, these are only the P1xxx codes. A complete list should include the P0xxx codes. P0xxx codes are generic (industry standard), but P1xxx codes are factory specific and will vary by manufacturer - P1000 is a good example of that. P1000 has different meanings across manufacturers.
If you get in the habit of using JTIS for this info, it is far superior that partial lists as it gives so much additional useful information such as drive cycle instructions, CEL info (red yellow lights), codes displayed or not, limp and restricted information too.
Old Nov 5, 2010 | 03:07 PM
xjrguy's Avatar
Always, REPEAT, always check the codes against your model year. As an example, here is an excerpt from some notes I saved from a technical guy a few years back:
Basically at 05MY P0121 code for TPS on all model lines changed to P2135. Failure
modes for P2135 are exactly the same as P0121. To add some confusion, on X200 and
X350 at 06MY for all engine lines, this code changed its designation to APP sensor while
X100 and X400 remained P2135 for TPS.
Then to add some more confusion, on X200 and X350, what was previously P0121 then
P2135 for TPS changed back to P0121 at 06MY.
I became aware of problems with this code as dealers were changing the throttle
bodies when they should be changing the APP, to add even more confusion, they were
also changing ECMs as the fault description in GTR states "APP sensor: incorrect start
value (not zero) sub-processor." It is the mention of the sub-processor that made folks
think that the fault is in the sup CPU of the ECM.
So you see, model year is everything, lest you go off on a tangent you don't want to be on!! Could get expensive.
Old Nov 5, 2010 | 04:49 PM
Gus's Avatar
Gus
I have most of all the model years with the codes and tips on trouble shooting on my page http://www.gusglikas.com/AutoRepairElectrical.htm I hope this helps!
Old Nov 5, 2010 | 05:09 PM
steve11's Avatar
ud
Yep, a couple of others that really screw things up especially for DIYers trying to diagnose simple engine malfunctions:
- Both the AJV6 (Duratec engine, Ford and Jaguar versions) and AJV8 engines have had two major iterations of cylinder numbering. This affects the relative firing numbering order (not actual, just the numbering schema) and the P02xx; P03xx code designator locations, so often, the wrong cylinder is being chased. The charts are correct if used.
- The AJV6 in the X-Type only uses one knock sensor and Jaguar arbitrarily chose the generic bank 2 (p0332/33) code location. This engine doesn't use a P0327/28. All other versions of the AJV6 and AJV8s do.
- No EGRs in the AJV6 and NA AJ26/27s but the charts hold the OBD locator position for optional models. Then in the 4.2, the EGR is present. I've known some who have tried chasing down an EGR failure on a vehicle that doesn't have one.
- The 4.2 uses a MAPS, none on the 4.0, so P110x codes are used. The 4.2 chart wouldn't fit a 4.0.
Can go on and on, but the point is - use the correct circa DTC charts for the car being diagnosed, and things go very smoothly.
Old Nov 5, 2010 | 07:20 PM
Oops... Maybe one of the mods can put a link to Gus' list of codes in the FAQ. Every time I need to look up a code I always have to go to Google, and it just seems weird that we don't have a link to the codes in the FAQs.
Old Nov 5, 2010 | 07:29 PM
Gus's Avatar
Gus
They are in the FAQ just go to the bottom of the page. I do stand to be corrected I do not have all years listed but will try to get that corrected.
Sorry!
Old Mar 4, 2013 | 07:20 AM
doowopfix's Avatar
P0171
Generic OBD Error Code Details for P0171
System Too Lean
What does this mean?
OBD Code P0171refers to
Basically this means that an oxygen sensor in bank 1 detected a lean condition (too much oxygen in the exhaust). On V6/V8/V10 engines, Bank 1 is the side of the engine that has cylinder #1. Note: This DTC is very similar to P0174, and in fact your vehicle may show both codes at the same time.
Symptoms
Possible sumptoms of OBD code P0171
You will more than likely not notice any drivability problems, although there may be symptoms such as a lack of power, detonation (spark knock), and/or a hesitation/surge on acceleration.
Causes
Possible causes of OBD code P0171
A code P0171 may mean that one or more of the following has happened: •The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry. •There could be a vacuum leak downstream of the MAF sensor.
Possible Solutions
Possible solutions include: •In the vast majority of cases, simply cleaning the MAF sensor does the trick. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling •Inspect all vacuum and PCV hoses, replace if necessary •Check for a dirty fuel filter and proper fuel pressure
Old Aug 27, 2014 | 04:33 PM
jcjcrespo's Avatar
Any one has a list of the OEM codes? My friend's 1996 XJ6 got scanned and it showed code B30F4???
Old Aug 27, 2014 | 05:38 PM
A late 'welcome' to the forum jcjcrespo as I see you have been with us for over a year before making your first post.
Your profile shows you have an XJS, you are asking for advice on your friend's X300 and you have posted about it in XK8/XKR forum.
Old Aug 27, 2014 | 07:57 PM
Gus's Avatar
Gus
See if this link helps JagRepair.com - Jaguar Repair Information Resource I am unable to find the code you listed.
Old Aug 28, 2014 | 12:24 PM
JagV8's Avatar
Repeat with a reputable scanner, that looks very suspect.
toronadomike
Jan 22, 2026 10:13 PM
trosty
26
Dec 18, 2022 06:40 PM
Jpav27
Jul 31, 2022 06:43 AM
JimMLiny
Sep 9, 2015 08:13 PM
