Won't crank after sitting for 3 weeks
Old Mar 14, 2014 | 04:00 PM
Conrad Man's Avatar
Default Won't crank after sitting for 3 weeks
First of all, greetings. Then, my car has been sitting for a few weeks with a 2-amp battery tender on automatic. Shows fully charged, but won't crank. All other systems seem perfectly functional but I just get a loud click from the starter. Car is a 2006 with 25,500 miles.
Battery tender has a 75-amp car-start function and that seems to have no effect. Display reads "DSC System Fault" when trying to crank.
Anyway I'm figuring the battery is toast, but this doesn't explain why the car won't crank when the car-start function is used--I've never had a car fail to crank using that function. I've checked and re-checked all cables. Any ideas?
I read here: https://www.jaguarforums.com/forum/x...t-fixed-52542/
that the DSC module might be faulty... should that go on the front burner or the back? TIA
Old Mar 14, 2014 | 04:11 PM
mike66's Avatar
Take your battery to a nearby Autozone and have it load tested. If okay, double check all connections, esp. grounds - there's one that goes from the body to the trans bell housing that corrodes - if no luck, could be a bad starter. Good luck.
Old Mar 14, 2014 | 04:17 PM
Conrad Man's Avatar
Thanks, assuming I need a new battery which ones are recommended for a 2006 XK8? I've searched the forums but must be using the wrong search terms.
Old Mar 14, 2014 | 04:54 PM
WhiteXKR's Avatar
Advance Auto and Sears both carry the Group 49 battery for this car. Just make sure you get or reuse (if possible) the vent kit since the battery is in an unventilated trunk. Store personnel are often clueless regarding the venting.
Car start functions on chargers may not provide clean enough power for the electronics in these cars if the battery is bad.
And welcome to the forum!...looks like we are neighbors.
Old Mar 14, 2014 | 05:48 PM
Conrad Man's Avatar
Thanks, I ordered one from Advance Auto...waiting on pickup notification... meanwhile presuming it doesn't have venting facility has anyone ever jerry-rigged one? Seems I could drill a hole the right size in the cap and plug in the fitting & tube from the old battery, which appears to be OEM ... It's a Varta with Jaguar logo, and a couple of the codes on it start with "95" which might indicate year. Not bad if it's almost 9 years old...
Old Mar 14, 2014 | 06:00 PM
test point's Avatar
The Advance AP battery I installed had the vent and reused the OEM tubing.
Old Mar 14, 2014 | 10:40 PM
Conrad Man's Avatar
Thanks guys. The new battery solved everything. And yes it has a port for the vent tube, and the guy was even familiar with the application. So he plugged the opposite end port. She's purring again, now if we can just get this sand and salt off the roads!!
Old Mar 15, 2014 | 08:41 AM
mike66's Avatar
Be careful with your charger. The battery was old enough to die, but check the voltage on the charger once the battery is fully topped up. If you're much over 12.6, then your charger is going to cook and kill the new battery. A "smart" charger will go into float mode once the battery is topped up.
Old Mar 16, 2014 | 04:05 PM
Conrad Man's Avatar
Thanks, my charger goes into standby mode once the battery is charged. Meanwhile does anyone know what these two wires might be? They are loose (unconnected) and in the vicinity of the positive cable. Sorry about the camera-phone pic quality.
Attached Thumbnails Won't crank after sitting for 3 weeks-xk8-extra-wires.jpg
Old Mar 16, 2014 | 04:16 PM
WhiteXKR's Avatar
They are for a device used during shipping of the car from the UK...they have no use once the car is delivered.
Old Mar 16, 2014 | 04:48 PM
Conrad Man's Avatar
LOL oh wow! At least the NSA wasn't involved. I hope.
Old Mar 16, 2014 | 07:29 PM
Jag#4's Avatar
I believe it would be MI6.
Dagny
Jun 11, 2024 01:06 PM
JarodL
Mar 7, 2024 01:39 AM
Bcrary3
Feb 21, 2023 04:29 AM
Broken_Spanners
Sep 6, 2015 11:34 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
