DSC System Fault? - FIXED
Old Apr 4, 2011 | 01:09 PM
Kevin93940's Avatar
Default DSC System Fault? - FIXED
Washed the car this weekend. When I started it up this morning, I got the "DSC SYSTEM FAULT" message and the yellow lozenge. Hitting the button did nothing. Drove the car to work - about 5 minutes. When I got to work, restarted the car, and everything seems to be normal.
Any ideas? Did I get a sensor wet or something when I washed the car?
Thanks...
Old Apr 4, 2011 | 01:10 PM
sidewalkman's Avatar
That would be my bet, clear the code and see what happens.
Old Apr 4, 2011 | 04:55 PM
Kevin93940's Avatar
Thanks, sidewalkman. I took the car out at lunch and everything seems fine now.
How do I "clear the code"?
K
Old Apr 4, 2011 | 09:03 PM
C5pilot's Avatar
Search the forum, it can also be an indication for a weak battery, bad connection, or bad cable.
Old Apr 4, 2011 | 09:22 PM
mohrd's Avatar
+1 on C5. Check your positive battery cable.
Old Apr 5, 2011 | 12:25 PM
buy a 50.00 code reader from an auto parts store, plug it in, scan for stored codes and then erase all.
Old Apr 11, 2011 | 01:27 PM
Kevin93940's Avatar
Thanks, everyone. Sounds like it may be the battery. I didn't drive the car for three days, and went out this morning and got the DSC SYSTEM FAULT message again. However, a restart cleared it up again.
The car is an '06 with 18,000 miles. Can the original battery be at the end of it's life??
K
Old Apr 11, 2011 | 02:03 PM
Check the cables, I've read that lots of cars here get issues with the positive cable and the ground, maybe a simple replace the cable.
Old Apr 11, 2011 | 04:49 PM
mohrd's Avatar
K
Sure, especially if it's the original battery. The mileage doesn't make as much difference as the age. With that low of mileage I would imagine it's also done it's share of sitting around without being driven. Any battery maintainer being deployed while it sits?
Old Apr 11, 2011 | 05:41 PM
Kevin93940's Avatar
No. No battery maintainer being used. Car was new on the dealer lot when I bought it in August 2008. So it had already been "sitting" for a while.
Old Apr 11, 2011 | 05:51 PM
mohrd's Avatar
Get your battery properly tested before worrying about any DCS system failure. There are a number of threads on here that started with "DSC System failure" and ended up being weak batteries.
Old Apr 11, 2011 | 11:00 PM
C5pilot's Avatar
A new 06 sitting on the lot in 08? Hope you got a really good deal on it. 2 years of depreciation before it ever drove off the lot.
My guess is your battery is ripe for replacement. Sat 2 years on a lot, then not driven much after that. Consider yourself lucky it lasted this long without a maintainer. But test it before tossing it just to be sure.
Old Aug 17, 2011 | 12:26 PM
Kevin93940's Avatar
Default Follow up
Thanks, everyone. Took the car to the dealer. The battery was faulty and they did replace it under warranty. They also had a Jaguar techincal bulletin on the DSC issue, and they also replaced the DSC module.
Old Aug 18, 2011 | 02:42 AM
Cadillac's Avatar
Hey , thanks for the update . I am happy for you as it was an easy and cheap fix rather than labor intensive job
Happy drivin'
Old Apr 18, 2020 | 05:56 AM
Richard Manser's Avatar
Smile DSC/ABS errors
For those having these problems a quick summary of my experiences. I started having intermittent DSC errors etc about 6 months ago. Tried all sorts, battery, brake switch etc. Played with Jaguar SDD software which was quite challenging but eventually it said the right hand front wheel sensor. Changed that a few weeks ago and no more problems, it seem it went intermittent.
Old Nov 12, 2020 | 01:12 PM
Mudjag2's Avatar
Default Asc abs fixed finally 2000 XK8
K
  1. Greetings friends. If you are having the abs asc issue I would definitely consider buying the pigtail to replace the bottom section lower section of the harness b4 doing anything expensive. I sent the computer to rebuilt in California , only 110 bucks but out and back in cost me plenty. There is a reason vendors sell that pigtail rather than the entire harness. Problem only solved when I cut in the pigtail. Cheapest fix. Then go on to other more expensive.
Old Nov 30, 2020 | 12:54 PM
3Jaguars's Avatar
What did the lower pigtail connect into? Do you have a part number? A picture? Thanks in advance
JarodL
Mar 7, 2024 01:39 AM
cissdm
May 3, 2016 06:02 AM
Corycarlo
Sep 5, 2015 11:41 AM
AL NZ
Sep 4, 2015 08:39 PM
