XK8 not responding
Old Dec 15, 2013 | 03:05 PM
Ashfieldbuilders's Avatar
Default Xk8 not responding
Hi, I've never been on a forum before so please forgive me if I make any daft mistakes. I have a XK8 2000, it has been stood in my garage for about 18 months with very little fuel, when I started it, it had developed a miss fire so I replaced a couple of coil packs, having done that it now doesn't respond as it should when I depress the accelerator, it will rev but it is delayed by a second or so. Can any body help me please?
Old Dec 15, 2013 | 05:26 PM
Welcome to the forum Ashfieldbuilders,
I've copied your question from New Member Area to XK8/XKR to get advice from members with the same model.
Old Dec 15, 2013 | 05:42 PM
carlxk8's Avatar
just a quick thought but as i work as a fitter on lawnmowers etc because they stand for 6 months usualy it is because the fuel in them has gone stale silly i know but it happens it tends to just go sticky try draining as much as you can and topping up
Old Dec 15, 2013 | 06:10 PM
WhiteXKR's Avatar
Besides adding fresh fuel, change the fuel filter and clean the throttle body.
Old Dec 15, 2013 | 06:23 PM
Paul Pavlik's Avatar
The engine revs are limited to about 3000 RPM unless the Transmission is in Drive.
Old Dec 15, 2013 | 08:18 PM
Gus's Avatar
Gus
Add BG44K to the fuel and drive the car.
Old Dec 16, 2013 | 03:23 PM
Thank you for your help, I@ll try your suggestions, not sure what BG44K is though so if you could enlighten me I'd appreciate it. Thanks again.
Regards Chris
Old Dec 16, 2013 | 03:51 PM
RJ237's Avatar
Fuel additive for cleaning injectors.
Old Dec 16, 2013 | 04:12 PM
Default Engine clean
Hi, I stumbled upon a u tube clip where the mechanic on the wheeler dealer uk tv program disconnected the fuel pump and connected some sought of machine and left the car running for about an hour, the results looked impressive. Has anybody had any experience of this???
Regards Chris
Old Dec 16, 2013 | 05:12 PM
Gus's Avatar
Gus
It is a fuel additive but not one you can get at all auto parts places. Most often available at your better repair shops.
Old Dec 16, 2013 | 05:26 PM
Originally Posted by Ashfieldbuilders
........ not sure what BG44K is though so if you could enlighten me I'd appreciate it. ........
Chris,
It's a US product:
BG 44K | 44K BG | Power Enhancer | Fuel System Cleaner | 44K Fuel | 44K Power Enhancer | BG44K Suppliers : BG Products
Available direct from the UK distributor:
Power Enhancer | BG44k | Petrol Engine Cleaners | Fuel Injector Cleaner
And also from Amazon UK:
BG 44K Power Enhancer Fuel System Cleaner - Free Delivery: Amazon.co.uk: Car & Motorbike BG 44K Power Enhancer Fuel System Cleaner - Free Delivery: Amazon.co.uk: Car & Motorbike
I've never used it but there's plenty of good reports from US members.
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
tlynch
Dec 31, 2020 01:58 PM
mikiep
Dec 20, 2019 07:37 PM
Johnken
Oct 2, 2015 10:12 AM
