03 XKR starter motor relay and solenoid locations please
Old Dec 24, 2024 | 02:04 PM
St. Stephen's Avatar
Default 03 XKR starter motor relay and solenoid locations please
Hello and Merry Christmas
Righio simple straight forward question I hope. I need to know the location of the starter motor relay and starter motor solenoid please. Any pictures would be greatly appreciated.
God Bless
Old Dec 24, 2024 | 05:14 PM
motorcarman's Avatar
The electrical guide has ALL the relay locations in the FRONT MATTERS section of the guide.
Gus will have ALL you need on his site. (jagrepair.com)
Old Dec 25, 2024 | 01:45 AM
Thank you very much,very technical schematics are a bit too complicated for me. Just need locations of those 2 components.
Relay position it says is"The starter relay EM50 brown RH enclosure relays". Still not sure where this is?
Old Dec 25, 2024 | 02:05 AM
Pistnbroke's Avatar
First if its RHD then the solenoid and motor are in one piece as its a pre engaged starter ,,the relay is in the under bonnet box,
To get it off you need to remove the steering rack and the RH steering arm then use the right tools ..the max126mm socket and bar from the front.
Took me about 8 hrs..its the worst job you can get.
I have written it all up with photographs..search through my posts. search How to Change Starter Motor RHD and LHD
Old Dec 25, 2024 | 04:27 AM
Good job, thank you for your help.
Old Dec 25, 2024 | 04:47 AM
michaelh's Avatar
Stephen,
The Electrical Guides don't just contain the wiring spaghetti. The location of the relay you seek is in the early part of the document:
Merry Christmas to you too.
Old Dec 25, 2024 | 05:01 AM
Bless you MichaelH, always there with help, exactly what I was looking for.
carps
Aug 22, 2023 01:31 PM
rckunze5
Aug 19, 2023 02:48 PM
chrisr8588
Mar 5, 2023 09:22 AM
DannyRobertHoward
Aug 29, 2022 05:00 AM
wrischan
E type ( XK-E )
Apr 6, 2021 07:30 PM
